No fire from the plugs? WTH
Old Apr 21, 2012 | 11:37 PM
lh4x4's Avatar
lh4x4
With no codes, I would be a little suspicious that the valves are not closing. Maybe the push rods are not adjusted right. Just an outside guess. No compression no fire.
Old Apr 21, 2012 | 11:45 PM
Iamdent1's Avatar
Iamdent1
That was exactly my first thoughts ih4x4, first thing I did was reposition and check push rod adjustment. I would think the plugs would fire even if the adjustment was not right. I have pulled the plugs and checked them outside the pistons they don't fire at all.
Old Apr 22, 2012 | 08:08 AM
Iamdent1's Avatar
Iamdent1
Ok so I'm a real dumb a##. I have got fire. Plugs won't fire if you have both plugs out of the bike. Says so right there in the manual.
Problem is now, bike still won't start?
Old Apr 22, 2012 | 08:13 AM
1931jamesw's Avatar
1931jamesw
Do you have the correct plug wire going to the correct cylinder?
Old Apr 22, 2012 | 08:49 AM
Iamdent1's Avatar
Iamdent1
Yes sir, best I can tell at this point is I am getting fire and I am getting fuel but I am not getting combustion. I have checked the battery for voltage but have not checked battery load test. Is it possible the battery could be weak enough to not let it start?
Old Apr 22, 2012 | 09:16 AM
scoobs's Avatar
scoobs
Check compression.
Old Apr 22, 2012 | 10:30 AM
DPete's Avatar
DPete
Cam timing ?? since you just installed
Old Apr 22, 2012 | 11:07 AM
1flhtk4me's Avatar
1flhtk4me
If you have fuel and spark,the next thing needed is compression.
Valve timing off?
Old Apr 22, 2012 | 11:17 AM
Iamdent1's Avatar
Iamdent1
OK so ran compression check, 120 psi front cylinder, 122 psi rear cylinder. That look about right?
Old Apr 22, 2012 | 01:05 PM
Iamdent1's Avatar
Iamdent1
My only other concern is am I understanding exactly where TDC is when adjusting the push rods.
