Help,what removes melted boot from exhaust?
Old Apr 23, 2012 | 07:41 PM
HRLYGUY2's Avatar
HRLYGUY2
Super fine wool.but must use a lubricant like.chrome cleaner.I use it on all my chrome even my custom truck rims .My old man is a chrome maker and learned it from him
RK Joy's Avatar
RK Joy
I had to clean the wife's sneaker off my pipes and I remember having to get the pipes hot before using some cleaner (but I can't remember what the cleaner was). Anyway I failed several earlier attempts and succeeded after someone gave me the tip to heat the pipes first. Good luck!
jberg's Avatar
jberg
Even 0000 steel wool will wear through chrome eventually. Oven cleaner or new Harley stuff. Colonel Brassy if you can find it. Be very gentle. Ask me how I know. Had to replace my shields with some one's take-offs after using green scrubber sponge.
Old Apr 23, 2012 | 07:53 PM
mastery's Avatar
mastery
You aren't going to believe this, but a copper penny. Pennies made before 1982 are 95% copper, and are softer than your chrome...won't scratch. I use one for tar, boot marks, and anything else that won't come off. Never even got the lightest scratch anytime. Just make sure it's before 1982, or else it's mostly made of zinc and is harder.
Old Apr 23, 2012 | 07:54 PM
a10182's Avatar
a10182
oven cleaner
Old Apr 23, 2012 | 07:59 PM
Chunker's Avatar
Chunker
I have used the Easy-Off on the cold pipes. Put a plastic sack or trash bag behind the pipe so it does not get on any paint behind the pipes. Shake well, get close, spray just a little and go have a beer. Use a plastic scraper, not metal and rinse well with soapy water afterwards. If necessary dry thourghly and repeat. Have had to do it 3 times and comes right off. I wouldn't use any abrasive steel wool at all.
Old Apr 23, 2012 | 08:03 PM
toastman's Avatar
toastman
I would, and I do...
On anything from my own bike to $50,000 show bikes that come through my shop.
Old Apr 23, 2012 | 08:10 PM
OH Bob's Avatar
OH Bob
Simichrome, it really works! Pink stuff in a tooth paste tube, made in Germany.
Old Apr 23, 2012 | 08:11 PM
2007z71's Avatar
2007z71
I use Mothers wax cleaner and it seems to work well.
Old Apr 23, 2012 | 08:12 PM
SB09UC's Avatar
SB09UC
A nickel works also, it's softer than chrome.
