polk MM651 install help needed
Old Apr 25, 2012 | 03:29 PM
Lemayco's Avatar
Lemayco
Default polk MM651 install help needed
I am putting the hog tunes speaker adapters in my 08 SG and it seems that I can not re-install the fairing bracket back on where it attaches at the lower outside speaker screw. The brackets are about 8" long and were replaced under warranty so they may be the upgraded bracket. Thanks for any help you can give.
Old Apr 25, 2012 | 05:21 PM
gonzo3426's Avatar
gonzo3426
try bending it some, i had to do that when i installed mine just so the screw hole would line up with the speaker mount hole...good luck
Old Apr 25, 2012 | 06:09 PM
jjnoble's Avatar
jjnoble
The hogtune speaker adapters are kinda sucky that way. Start the screw on the speaker, get it seated good but leave it loose. Then start the other side, you have to put some pressure on it but it should go, be careful not to cross thread it.
Old Apr 26, 2012 | 12:42 AM
Lemayco's Avatar
Lemayco
Thanks guys got it. Most of the problem was that the speaker connectors were way to close to the bracket and I was worried about a short. I had the speaker connectors located on top and bottom, I rotated the speakers 90 degrees so they were located to the left and right. Also did slightly bend the bracket for a perfect fit.
JMC22
2014-2024 Touring Models
May 13, 2015 11:53 AM
deuce_streetbob
Aug 12, 2013 04:11 PM
Ryder7140
Audio Systems
Jun 16, 2013 11:42 AM
WillieC
Jun 5, 2009 04:52 PM
alandchris
Feb 17, 2009 05:12 PM
