ohlins
Old Apr 27, 2012 | 08:46 PM
djack's Avatar
djack
Default ohlins
finally got hooked up with Howard and my 2-2A's are on the way for my 12 SG
Old Apr 27, 2012 | 09:50 PM
shadowchaser's Avatar
shadowchaser
Another soon to be very satisfied customer!
Old Apr 27, 2012 | 09:52 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Follow Howard's instructions on set-up and you will be fine. Welcome to the growing hoard!
Old May 1, 2012 | 01:34 AM
SharkBite's Avatar
SharkBite
Just spoke with him tonight for a bit. My order sheet was supposed to be in my email but it got lost in space somewhere. Can I ask your 'stats' as far as ordering the 2-2a's? That's what I was going to order but after speaking with him I'm a bit on the fence between that and maybe the 3's. I guess the 3's (at least one set) are lower the way I understood it and that's one thing I'm looking for. Reading the web site though they would also not be adjustable which concerns me. the 2-2a's appear to be just a hair higher but adjustable. Appreciate your input in advance
Old May 1, 2012 | 02:17 AM
grbrown's Avatar
grbrown
Wink
Both #2s and #3s are adjustable for sag, or pre-load, in other words to compensate for the weight of the bike with rider(s). The #3s also have adjustable compression & rebound damping via a sweep valve. So it is the #3s that have more adjusters.
#2s are emulsion type, with mixed gas and oil, while #3s are separated and they also have superior damping. When I talked through the options with Howard (about 3 years ago now) I was happy the #3s were the better choice. If you ride 2-up a lot they are worth considering.
Old May 1, 2012 | 02:44 AM
SharkBite's Avatar
SharkBite
I thought emulsion was something about the paint finish lmao......makes more sense. I definitely want the ride as low as I can but don't want to compromise the ride quality otherwise it defeats the purpose of putting 'em on. Decisions, decisions
Sorry, didn't mean to hijack
Old May 1, 2012 | 03:43 AM
grbrown's Avatar
grbrown
Wink
Phone Howard and talk through what you want with him. There are limits to how low you can go and still get the high quality ride Ohlins can give. They are not shocks for looks, but high performance!
Old May 1, 2012 | 05:18 AM
djack's Avatar
djack
well shark bite, he did caution me about staying with stock length,he I'll lose an inch right off the top from sag and then my load of about 450 lbs. he said that's a lot of weight lol.but he told me he doesn't make reccomendations, he sells you what you want, so I'll see I may be ordering some longer ones
Old May 1, 2012 | 06:30 AM
JJHOG's Avatar
JJHOG
I have the 2-2a's. These are 12" shocks that have about 3 1/4" of stroke. That is more stroke than you can get out of the 3-3's and frankly will give you more preload adjustment compared to the 3-3's. Given you weight factor and riding 2up I would suggest the 2-2a's and let Howard do his magic with building the shocks and supplying just the right spring for the job.
Old May 1, 2012 | 06:33 AM
grbrown's Avatar
grbrown
There is more to shocks than stroke! The damping qualities of the #3s are superior to the #2s, which is why they cost more. I bought them over #3s because of that and the ride is sublime. Any Ohlins, however, is likely to be better than most if not all others.
