Wonder if anyone has any suggestions on how to keep sunglasses still while riding and not moving around. I have a LRS shield which works great but no matter what shield I use my sunglasses move around slightly.
When I press the center above my nose I can make it stay still and vision is better because signs and everthing else is not blurred from the movement. I know a tighter fitting pair may be the answer but for a long ride it would not work after awhile tight fitting glasses don't cut it. Anyone else experience this?
I bought a pair of prescription, polycarbonate, recreational wrap-around sunglasses and have no problem at all. If you don't wear a prescription, then I would think that any wrap-around sunglasses would do the trick!
Wonder if anyone has any suggestions on how to keep sunglasses still while riding and not moving around. I have a LRS shield which works great but no matter what shield I use my sunglasses move around slightly......Anyone else experience this?
Can't believe you haven't been following the "buffeting" threads recently....it's all in there.
It boils down to air coming from under the batwing. Unless you use one or more, whatever it takes for you, of the several deflector devices out there for a SG, you will have enough dirty air coming up from below to move your glasses, your helmet (if any), and anything else you wear, all over the place. Ruins the fun.
If that doesn't solve your problem you could possibly try a staple gun
with 1/2" staples.....
CAUTION!!!!! 1/2" is too long for this job! If you use a staple too long it will go something like this:
"OK.....Better mark the spot with a Sharpie... only want to do this once!"
"OK.... lined up perfectly.... Now, depress the safety...... hold steady..............aaaaand. LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB LUB"
