PIAA H4 Xtreme White Headlight
Old May 10, 2012 | 09:03 AM
hoethree's Avatar
hoethree
Years ago I played around with alternative bulbs for my FXR2's headlamp. Tried several brands including PIAA.....all with a higher voltage than the stock replacement bulb. Several of them worked great but tended to burn out quickly.......the last one I used totally burned out the bulb socket in my headlamp and I then found I could no longer purchase the replacement headlamp assembly from Harley. Had to do some re-wiring and went back to using the stock bulbs. Just my experience.
Old May 10, 2012 | 09:41 AM
103 sedona orange's Avatar
103 sedona orange
Check out this guy. You can talk to him on the phone.
http://danielsternlighting.com/
Old May 10, 2012 | 08:28 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
e code housing,great cheep upgrade for halogen bulbs,there fluted and give a nice pattern,about 30$
Old May 10, 2012 | 09:00 PM
Henry89's Avatar
Henry89
Question
Originally Posted by dbell66253
They are not completely plug and play, you do have to run another power wire, but the bulbs do plug right in, if you get the bi-xenon you have low and high beam, and there is a metal deflector in the bulb that helps a lot with the lighting pattern. You will often here people say the lights blind oncoming drivers, not true, if you have them properly aimed there will not be a problem. I had HID's for 2 years before I recently went to LEDs, I absolutely loved them, BTW I went with a 6K light, slight blue but nice and bright, 8K was too blue for me, and 5K is good also, I just happened to like the slight blue color.
So this is the bulb I just got. Are you saying I have to add another power wire? From where?
Thanks!
Old May 10, 2012 | 09:48 PM
roadhog96's Avatar
roadhog96
I have a 96 RK that I bought new and I've had the H-4 extreme white headlight bulb in for just about the intire time I've had the bike. It was one of the first upgrades I did. I also have the H-3 extreme white passing light bulbs. These bulbs have a very bright white color and at night time they really make dark roads a lot more visible than the stock bulbs. Looks almost like daylight with all three lights on. You can actually see further down the road with these. I put one in my wife's bike also. We did have one H-4 bulb fail early on but the rest are still going strong. I plan on continuing to use these bulbs because they just plain work well.
Old May 10, 2012 | 10:17 PM
Xzotik's Avatar
Xzotik
PIAA 70456 Xtreme White Plus H4 Anti-vibration Bulb by Piaa
Old May 11, 2012 | 06:44 AM
dbell66253's Avatar
dbell66253
Thanks!
I was refering to HID's not being completely plug and play, the bulb you have will fit ok.
Ernest T
Apr 15, 2013 09:50 AM
QC-RAIDERS-91
Apr 18, 2012 07:45 AM
RadioBob
May 20, 2011 07:32 AM
eric95
Oct 21, 2008 11:22 AM
jurob
Apr 4, 2008 06:06 PM
