PYO Monkey Bars: Soooooo pissed!!!
Old May 9, 2012 | 07:24 AM
hog95023's Avatar
hog95023
They are the 12's
Old May 9, 2012 | 09:07 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Originally Posted by 09FLHT
Dont half *** it. Make Yaffe step up. And while your at it, tell him you want a partial refund for having to wait so long and deal with so much B.S. for his overpriced bars.
Waaaaa Hahahahahahahaha good luck with that. Apparently you have never delt with Yaffe Customer Service.
Old May 9, 2012 | 09:15 AM
monumaker's Avatar
monumaker
This is why I went with different bars. PYO is a joke. For that money, they just plain suck.
Old May 9, 2012 | 10:06 AM
Geoff's Avatar
Geoff
I'd change grips or return the bars.
Problem with spray paint is throttle rotation might scratch the paint. This could look bad, depending on the size of the little holes in the grips.
Old May 9, 2012 | 11:22 AM
bagman1's Avatar
bagman1
Originally Posted by hog95023
They are the 12's
I am about to pull the frickin wires on a set of 12s. Were you able to use the stock wires or did you need the extension kit? I am removing 16s and going with 12". Yaffe said to go +8 but that looks to be too long also, what did you end up using? I still have throttle cables.
Suggestion for the grips that came up short, use a tubing cutter and trim that amount off the tip and it will sit flush against the stop.
Old May 9, 2012 | 11:32 AM
rg_dave's Avatar
rg_dave
The bars work with grips that match HD grips. I found that out with a set of Ness deep cut grips. They left a 1/4 inch gap. HD grips were perfect. PM grips are perfect. Nothing wrong with the bars. If you trim the bars you will have to re notch the TBW side.
You can use the stock length wires with 12s. Just reroute the plugs inside the fairing to under the radio. +6 cables and brake lines will work fine.
Old Aug 11, 2013 | 12:36 PM
DevilGlide's Avatar
DevilGlide
Default Monkey Bar wiring length
Will the stock wiring work if you run INSIDE the bars on 12" (2008 roadglide)...what about the throttle by wire?
Old Aug 11, 2013 | 01:29 PM
Jersey_Marine's Avatar
Jersey_Marine
Id be pissed too but nothing surprises me anymore..the paint seems to be the best option as long as the surface is prepped right and it doesnt start to flake off
Old Aug 11, 2013 | 02:36 PM
Dew Me's Avatar
Dew Me
I just realized I never updated this thread. So since it has been revived I'll provide closure:
I called Yaffe and they hadn't had this occur b4, but understood. They said they would be happy to make me a special set with end to end chrome. A month or so. They said they would be happy to take back the first set of bars even if I use them while I'm waiting on my new ones.
Originally Posted by Dew Me
Second, is that after a day or two of riding I may find out that what many are saying is true, and that I actually want 12's.
I did ask Yaffe on the phone if, since they were doing a special job for me anyway, they could make them as 11's. Thought I'd split the difference between 10 and 12 and they might still stay close enough to the fairing to make me happy aesthetically. Nope, no-can-do. After 14 months I guess I feel the same way now as I did then: 12's would've been best comfort-wise, but 10's are best aesthetically. 10's are leaps and bounds better than stock in every way. I am still planning to do the FBI Drop Seat that will give the effect of raising the bars.
Old Aug 11, 2013 | 05:40 PM
HD REBEL's Avatar
HD REBEL
Exactly why I went with LA Choppers Prime Apes. Tried the black paint but the throttle grip scratches the paint off. Better bars at much less cost and they come completely chromed!
Attached Thumbnails PYO Monkey Bars: Soooooo pissed!!!-044.jpg
