Clutch Cable change question....
Old May 7, 2012 | 09:06 AM
skydude426's Avatar
skydude426
Like I said in my previous post, a snap ring pliers will allow you to remove and install the internal type snap ring very easily. Nothing will fly apart. All that's under it is the 3 ***** the ride in oval shaped channels. It's nothing to be concerned about. I removed the exhaust when I did it. Make sure to install new exhaust gaskets to avoid leaks.
Old May 7, 2012 | 09:51 AM
rdc401's Avatar
rdc401
Originally Posted by LMmarine86
I guess I'll be the only one to say the other way. For me, yes, I was able to loosen the clutch cable enough to just unhook it. Screw in the new clutch cable to the housing and put the metal link back on the end of the new clutch wire and hook it back into the pulley. Be sure you have the adjustment nut on the clutch cable adjusted to have the most slack possible. If you force it on the pulley it will get jammed with the ***** and you'll have to take the entire thing apart to allow those ***** to get free. It can be done though and it saves some time. Just be sure that you test the mechanism after hooking it that it all moves freely before putting it all back on the tranny.
this is the way i done a buddys clutch cable when we changed his bars.
Old May 7, 2012 | 10:21 AM
TUCCI's Avatar
TUCCI
Wow between the video and all the input I have a pretty good idea what Ive gotta do....Im going to try it without removing the clip but if it looks like the cable end could get jacked Ive got a snapring pliers already. I just changed fluid in my tranny.... I guess I shoulda waited. Taking the header back away from the bike without totally removing it is what Im trying first. Thanks for all the input...I appreciate it Tucci
knights
Jan 13, 2013 02:53 AM
Reaper_ggy
Jul 14, 2011 03:38 PM
lowlife801
Shovelhead
Feb 25, 2010 05:45 PM
1nuckenfut
Feb 14, 2008 11:14 PM
Pastor John
Jan 5, 2007 09:33 AM
