31/68 sprocket
Old May 23, 2012 | 08:19 PM
Joker65's Avatar
Joker65
Originally Posted by boogaloodude
On my bike with the 30/68, 80 mph on the freeway is about 3200 rpms. With the 31t, it would drop approx 100 rpms. 3100 vs 3200 at 80 mph is not enough of a difference that one would feel comfy and the other would feel frenetic. Since the whole excercise (for me) was to increase torque, it was an easy choice.
Nice vocab Boogaloo!!
Old May 23, 2012 | 08:51 PM
skulz1's Avatar
skulz1
Does a rider have to re-calibrate the speedo upon completion of this gearing mod?
Old May 23, 2012 | 09:01 PM
speakerfritz's Avatar
speakerfritz
yep...have the parts to do the 30T/68T. Got a speacial 3/4 drive with a hole and a 6ft chrome steel solid bar to break that bad boy with.
Old May 23, 2012 | 11:29 PM
silverado636's Avatar
silverado636
Default 30t part#
Can someone give part# 's and suppliers? I want the 30t up front as I have a 68t in back already.
thanks
Old May 24, 2012 | 01:20 AM
mike5511's Avatar
mike5511
I've got a 31T, to go with my 68T, but haven't put it on yet. Will do so this winter most likely. Somebody asked about speedo and yes, it will throw it off. Not a big deal to me. There can also be some issues with cruise control that need addressed as well. (I forget all the particulars and would have to go back research it again.) Different year models require different solutions if I remember correctly.
Old May 24, 2012 | 02:03 AM
Mike's Avatar
Mike
I don't know about the cruise issue (don't have cruise), I was able to reprogram my speedo through a tts calibration. 6th gear light works properly, too.
lol, I guess those remedial english correspondence courses are going to come in handy after all.
Old May 24, 2012 | 08:29 AM
gmc's Avatar
gmc
Your speedo will be fast, mine was 2-3 mph fast with the stock gearing, with just the 68t rear sprocket change I was about 8 mph fast. I had the SERT so had to send it to TTS to upgrade to Master Tune ($100), then the dealer can change the settings in the map. Note: you have to have the dealer run TTS program before you send it in to verify you Sert is upgradable.
Cruise control doesn't set above 85 mph so if you want to cruise 80 you need to recalibrate your speedo else you setting it at 85 your probable doing 77 mph.
Old May 24, 2012 | 01:24 PM
nvsteve's Avatar
nvsteve
I have the stock (32) and changed to a 68T rear on my 07. According to my GPS when the speedo reads 75 I'm actually going 70.
Old May 24, 2012 | 06:54 PM
Brick0044's Avatar
Brick0044
Just ordered my 30T for my 2009 FLHR!! Looking forward to this project... and the outcome!
You will love it. Just gives you that little boost that you're lacking. I like mine. Hope we get a nice weekend, I'm in the cities too.
Old May 24, 2012 | 07:02 PM
qtrracer's Avatar
qtrracer
Sounds about on par with what I have observed when I have been thru those radar "Your Speed __" things on the side of the roads. I have the 32/68 set up at this time.
