Fork Torque help needed... God help me!
Old May 17, 2012 | 06:57 AM
jaysnafu's Avatar
jaysnafu
Default Fork Torque help needed... God help me!
So we were attempting to get my bike (2011 RKC) built back up and ready to ride in the next few days after waiting weeks longer than expected, when we were finishing up my front end.
Everything came together just fine when it came time to tighten it all up we could not, for the life of me find the torque specs in the service manuel for the two bolts at the very bottom of the right side that holds the front wheel axle in place.
SO... by buddy and I agree on what we thought was a good enough torque and he snapped the damn thing off! Broke the bolt. Now I have to get new lowers and start all over.
I'm headed to a HD in the next 48 hrs to get a new set off lowers since the bolt that broke off seems to be one of the few, if not only ones that cannot be fixed or replaced.
DOES ANYONE KNOW THE TORQUE SPEC FOR THIS? So I do not "guess wrong" again?!
Thank you for your help in advance.
Old May 17, 2012 | 07:16 AM
BugBYter's Avatar
BugBYter
Originally Posted by jay24601
.... we could not, for the life of me find the torque specs in the service manuel for the two bolts at the very bottom of the right side that holds the front wheel axle in place.
It's under "Front wheel removal / replacement" in the manual. The 2005 and 2012 manual both list the torque as 132-180 INCH POUNDS
Which is only 15 ft lbs....
IIRC those are studs and you should be able to replace them.
Old May 17, 2012 | 07:17 AM
jaysnafu's Avatar
jaysnafu
Bug - so your saying the sixty he was applying was a bit much? lol
Thanks man.
Old May 17, 2012 | 02:06 PM
tom071200c's Avatar
tom071200c
yep just did chrome lowers on mine and i set mine to 15 ft/lbs also. doesn't seem like a lot but it does the trick
Old May 17, 2012 | 02:20 PM
Spur56's Avatar
Spur56
I thought those were studs and could be replaced?
Old May 17, 2012 | 03:44 PM
jaysnafu's Avatar
jaysnafu
yes they are. My mistake. I was able to recover one of the studs in my oem set and use it. Thank you. That saved me DAYS of not riding. Now onto further assembly, and Apes...
Custardglide
2014-2024 Touring Models
Oct 23, 2016 01:27 AM
Psi23
Sep 5, 2012 09:02 PM
MUTZ
May 19, 2012 08:56 PM
Matt0987
Sep 12, 2011 08:13 PM
magnum629c
Apr 14, 2010 02:38 PM
