So I am just curious as to how my "bike" is calculating mpg. When I fill the tank and take a look at the reserve calculation on the odometer on a full tank it reads 236. That would calculate to 39.3333 mpg. I filled the tank and have ridden 139.9 and the reserve says 94 so that would calculate to be 38.98 mpg. So my big question is how does the "bike" calculate that number? I have figured I am getting around 36 mpg so I guess it is somewhat close although I would like to squeeze a couple more mpg out. I was getting about 42-45 on my 03 RKC and would be happier in that range.
I am not sure how much I believe the calculated number but just wondering where that comes from. Is this being calculated by the ECM based on data it has collected from past rides? Has anyone looked at theirs after a fill up and what number does yours say?
I am going to order the PV tomorrow and was wondering if with a "spot on" tune will this number change?
Thanks
How did you find this number on your bike? Is this some newer bike thing or something I haven't found on my 08 yet. I'm new to these touring bikes and didn't know we could even see a how many miles left type of thing.
I have a 2011, not sure about 08 but there is a button by speedo that allows you to scroll through your odometer. Actual miles, trip A, trip B and fuel reserve.
From: Western Illinois, land of bad roads, and corrupt politicians
It's an estimate calculated according to the way you are riding at that moment. If you really hammer on the throttle a lot, the remaining is going to go down as an estimate of how much farther you can go. Same thing if you slow down to 50 and hold your RPMs to around 2200, your remaining estimate will go up.
Tap the ODO reset until your see an "r" on the display next to a number. That is the "remaining" miles estimate.
OP, it is based off the ECM sampling of riding conditions and the amount of fuel left in the tank, I'm not sure how often it samples. It is not accurate, that's for sure. I'm sure you know by now how accurate your gas gauge is. When my fuel remaining gets close to 0, I have about a gallon left. A hard twist of the throttle for a short while can drop my fuel remaining by many miles left. Baby it for a while and you can actually watch it climb. Only way to calculate MPG is with a different device or manually by recording mileage between fills.
'Inaccurate' does not accurately describe just how inaccurate those things are.
The only 'accurate' way of calculating mpg is to divide the number of miles by the number of gallons consumed.
I had a car a few years ago that gave various mpg data, including actual mpg. It was fun to try and get it below 7mpg, moving away from a stop, and trying to get it over 94mpg going down a long gradient at speed, with my foot off the gas.
And that is all those figures are good for! Fun. Check your mpg Leftcoaster's way and learn the way your bike works for you. It is the only way!
+1 the remaining miles calculation is not accurate thats based off an average from life cycle with a safety margine built in
