Tru-Trac etc.
Old Jan 6, 2007 | 12:46 AM
ext1bab's Avatar
ext1bab
Default Tru-Trac etc.
I'm a new HD 07 SG owner and have read a few posts about aftermarket products to improve stability such as Tru-Trac and ride-Str8. Just wondering if anyone has installed these and if it is really necessary. I haven't experienced any issues with handling yet, but I only have about 2k miles on the bike. Just wondering if I am at risk of having a problem in the future next time I am cornering at freeway speeds...
Thanks in advance for any advice you may have on this.
Old Jan 6, 2007 | 12:52 AM
zubaugh's Avatar
zubaugh
Default RE: Tru-Trac etc.
I have a true-track on my 06 CVO SE UC and my 05 UC. I won't ride without one. However, I don't ride freeway speeds. I have found that without a true-track at speeds over 90 a wobble is present. Annoying but not a problem until I go past 115 where it turns into a bit of a tank slapper. With the true-track I top end at 128 with no wobble.
At freeway speeds you may have a rear steer effect if you go into a hard corner with weight.
Again, I won't ride hard and fast on any of MOCO's HOG's that have the rubber mounted swing arm without the true-track. Best wishes if you do.
I have no experience with the STR8 but have heard it works well also.
Old Jan 6, 2007 | 12:57 AM
ext1bab's Avatar
ext1bab
Thanks Zubaugh. Did you do the installs yourself?
Old Jan 6, 2007 | 01:55 AM
Bryan TTM's Avatar
Bryan TTM
i have a truetrack...its very nice...kdietz has a ridestr8, its also very nice...both cost bout the same...both do the same thing...it was definitely worth the money...buy one, you'll be happy you did
Old Jan 6, 2007 | 01:56 AM
AR4CE's Avatar
AR4CE
I got my tru-trac installed by the manufacturer at the ralley this year
Installation isn't hard at all from what I saw- biggest thing is straightening a surely tweaked crossmember.
TimLScheffer
2014-2024 Touring Models
130
Jul 22, 2020 01:49 PM
TimLScheffer
Jan 20, 2015 04:33 PM
ywhat2000
Jun 13, 2008 03:32 PM
dpitts
Mar 9, 2008 01:47 AM
novazeus
Screamin Eagle CVO Models
18
Jul 20, 2007 02:58 AM
