Plus.... anything you touch gets a drop of blue threadlocker...... even if it's some chrome doodad that doesn't do anything except look pretty.
I have to say that is a great idea, I cannot believe I did not even consider that and yet it seems to make the most damn sense when my biggest fear is all the things on the EG that I worry might loosen up/back off. Then again, most folks would agree that sense is not my most abundant item on a good day.
From: Western Illinois, land of bad roads, and corrupt politicians
That would be one of the MANY reasons Marines are called JARHEADS.
US ARMY 1971-1976
VietNam Veterans of America
Patriot Guard Rider
Disabled Vet
Did I mention A R M Y ?
I tried to join the Marines 5 times..... they kept turning me down..... I kept passing the IQ test.
No disrespect intended....... it just seems to work out that way.
Proud member of the 1000 yard club.
As said, a small kit is all you need. I carry a multi-tip screwdriver with torx bits, combination wrenches of the common sizes for tightening things that may come loose, a set of hex head sockets for the same. A pair of pliers. A siphon hose in case you run lower on fuel than you (or someone in your group) realized. A tire pressure gauge also.
I use a 1/4" ratchet with extension, u-joint and the common size sockets and a 1/4" x 3/8" adaptor thrown in just in case you need 3/8" drive items.
A few zip ties. A couple bungee cords. It sounds like alot but it's not and fits in my right saddle bag with room to spare. That being said, these modern Harley's are incredibly reliable. Over the past 5 yrs I've put a combined 150,000 miles on two Touring bikes and had VERY FEW problems. The only thing I've had happen in this time is a broken kick stand spring (a $7 part and I carry a spare in my kit - takes 5 minutes to replace if you have pliers). The stock shifter linkage is a weak point so replace it with one that has Heim Joints. My first one wore out on me at 70 mph and I pulled over and replaced it with a spare I carry (took 10 minutes). That's it. No other problems.
Any common problems can be eliminated by checking your fasteners periodically and keeping up with maintenance. Also know your bike. For example if you know it uses oil be sure to have a quart of oil in your kit if you take a long trip. Keep an eye on the rear shock pressure depending on how you load the bike, if you ride with a passenger, etc. Use the H-D air pump only DO NOT use a standard air compressor or you'll blow it to pieces as the volume of air in that system is very tiny.
I also carry a spare tail light, passing lamp and turn signal bulb (I tape them to the inside of the saddle bag lid in bubble wrap).
PS: I use Captain Itch's leather tool wrap and it's great. Holds lots of stuff and rolls up very neatly for your saddle bag. Keeps them from rattling around and getting scattered too.
I hunkered down and bled with Marines...... glad you took it the way I intended.
I have more good friends in the other services than I can count that I have shared many a beer and occasional bar fight with. And any man that served in Vietnam is a man I'd gladly share another cold one with.
I'm glad to see that the kit doesn't need to be huge but rather a jack of all trades (and experience) specific multi use items. In regards to the pump I see I need to head to the dealer and pick one up. Does the system hold pressure well or is it like tire pressure which bleeds fairly regularly? The wife is fairly light but my tank *** is not exactly a small load. Should I check it as regularly as tires whether or not the load changes frequently?
