How much primary oil?
Old Mar 30, 2017 | 12:42 PM
  #31
Daprez1963's Avatar
Daprez1963
Originally Posted by xcbullet
One quart gives me that red line if I drain over night or take all apart. I usely don't pull the round cover as less screws with inspection cover.
So you don't pull cover as in derby cover? I was shown to take that off and fill it thru the inspection opening...
Old Mar 30, 2017 | 12:57 PM
  #32
xcbullet's Avatar
xcbullet
Correct, I have in the past to make sure one quart is right, but now just use one of those small long funnels u get at Walmart or whatever. It fits just under the chain, dump 32 once and good to go.
Old Mar 30, 2017 | 01:08 PM
  #33
Mikey 1450's Avatar
Mikey 1450
I always drain my Fluids with the Engine Hot, mine always takes more than a Quart and that is also the best time to check your primary chain adjustment and adjust your clutch.
It would be nice if Harley could add a Fill to spill plug in the primary cover.
Old Mar 30, 2017 | 01:11 PM
  #34
xcbullet's Avatar
xcbullet
I change mine so often the clutch has not changed two years and 27,000 miles.
Old Mar 30, 2017 | 01:13 PM
  #35
RK_Classic's Avatar
RK_Classic
Yup transmission fluid funnel does the trick. But I did see harley makes a primary funnel as well.
rk classic
Old Mar 30, 2017 | 04:43 PM
  #36
btsom's Avatar
btsom
For fluid changes (not starting with a dry primary), how much you should add depends on how much you got out. A HARD, SOLID fixed quantity will always have the chance of an overfill or under fill if the draining job not thorough or very thorough.If you are **** about it, check the level as the book describes, there is no substitute for that. I have read the the guys who service the Police bikes, especially those used in maneuvering demos and contests, OVER service the primary for extra clutch cooling. I have never gotten any solid verification on this, however. In my experience (ONE guy, one bike) how easy it is to get neutral depends more on clutch adjustment AND a good gear oil in the transmission rather than lube level in the primary. Yes, I know what the book says, I have and use the book.
Old Mar 30, 2017 | 04:52 PM
  #37
TheGrandPoohBah's Avatar
TheGrandPoohBah
Consider this:
One of my trucks, in the manual, states the coolant capacity. When I change the coolant, do I put that much back in there?
NO!
I fill it to the appropriate level, however much it takes.
Let that marinate, it will come to you in a while...
101ABN_17FLHTK
Milwaukee Eight (M8)
22
May 15, 2017 11:34 AM
SmokeyJoe101
Oil Archive (no new posts)
Jul 22, 2016 10:43 PM
Streets of Fire
Oct 6, 2008 04:49 PM
hunter123
Sep 14, 2008 07:23 AM
badlandr
Aug 16, 2008 07:10 PM
