Compression Ratio?
Old May 23, 2012 | 01:29 PM
andyp's Avatar
andyp
Default Compression Ratio?
I have got a 95 in build with 030 head gaskets and HD flattop pistons ,Heads were milled .005 according to machine shop. What should my compression ratio be? How can I check it.I built this in 07 and have gone thru 2 starter clutches and one high torque starter.I am going to probably go with a thicker head gasket and compression releases.
Old May 23, 2012 | 01:35 PM
mgmmgm's Avatar
mgmmgm
I think comp releases would be a good idea.
I did not have them on my 07 FLSTF 103 build, that was 9.8:1 comp. Hot start issues comps would have been a plus.
Old May 23, 2012 | 01:41 PM
andyp's Avatar
andyp
I am probably going to add releases .I wish I would have known better when I did my top end build.I asked and was told I would,nt need comp releases.I suspect my heads were milled much more than .005.
Old May 23, 2012 | 02:14 PM
speakerfritz's Avatar
speakerfritz
I was told I would not need compression release on my 103 upgrade....but I put them in anyway.... if I don't open the MCR's ...bike will not turn over. MCR's always make sense if your heads are going to be off.
Old May 23, 2012 | 02:37 PM
fabrik8r's Avatar
fabrik8r
You gave all the info except what's critical, What Cam? Corrected compression is what you want to look at try the Big Boyz calculator on their website, but it does sound like you need some compression releases.
Hoytman1968
Engine Mechanical Topics
May 29, 2016 07:21 AM
Sallyman
Mar 21, 2011 08:14 AM
Night Hog
Exhaust System Topics
Feb 5, 2010 02:09 PM
FLTR2008TRIKE
Jun 5, 2009 10:00 PM
touron2
Mar 26, 2008 08:48 AM
