front forks leaking oil
Old May 24, 2012 | 08:29 PM
blackcat1954's Avatar
blackcat1954
Stage IV
Default front forks leaking oil
I just chromed out the front end & now both forks leak a small amount of fork oil around the back screw that holds the upper can. The top seal is dry,I took to repair shop & they replaced the seals & the said they look good. they replaced anyway & now it still leaks a small amount.(a day of ridin will show it) If the forks had a nick i could understand but both forks? Inspection showed everything was fine,not a problem with the forks,sure has me & my mechanic stumped,any help would be appreciated
Old May 24, 2012 | 08:39 PM
CLL375's Avatar
CLL375
I thought mine were leaking to. Everything checked out okay so I started looking around. It turned out the neck bearing grease was leaking on to the lower tree and when I rode it would drip a little. I just wiped up the excess grease and all was well. The heat will do it.
Old May 24, 2012 | 08:43 PM
blackcat1954
Stage IV
thankyou for the info but not sure why it didn't do it before I changed the front forks,it just started as soon as I changed out the forks
Old May 27, 2012 | 06:37 PM
hog95023's Avatar
hog95023
any update? mine started leaking when I had the front end chromed too.
tokey666
Aug 20, 2015 12:50 AM
m i k e
Sep 4, 2012 06:53 PM
DanDman
Jul 10, 2011 07:55 PM
00 FX
Jun 25, 2010 08:37 PM
deluxe
Nov 13, 2007 05:09 PM
