Need HELP!
Old May 31, 2012 | 07:58 AM
Moe55's Avatar
Moe55
When was the last time the fuel filter was changed? If you don't have any codes for a bad sensor I would look for an intake leak.
Old May 31, 2012 | 08:00 AM
X Iron Butt's Avatar
X Iron Butt
BTW with a Power Comander you will never see a code for lean because your O2 sensors are disconected. If you are going to check the hose I would have a filter in hand while you are in there. Should probably check fuel pressure before dis assembly.
Old May 31, 2012 | 08:01 AM
soft 02's Avatar
soft 02
Originally Posted by LeeH
Sticky intake valve? Do a compression check and a leak-down test.
Intermittent injector? You can pull the injectors and have them tested for flow, leak, spray pattern and coil resistance.
I wonder if it still has the 8* injectors and time for the 25* ones.
Old May 31, 2012 | 08:03 AM
Gator252's Avatar
Gator252
You might try loosening your gas cap as well...could be that it is not venting properly and creating a vacuum...
Old May 31, 2012 | 08:41 AM
rh8234's Avatar
rh8234
My wife's 06 Sportster acted similarly only when the engine was hot. turned out it was a bad crank possition sensor. Only acted up when hot. Never triggered any codes. Always ran great until the engine got up to operating temp. Replaced the sensor and it's run flawlessly for 4 years now.
Old May 31, 2012 | 08:49 AM
TUCCI's Avatar
TUCCI
I would call Fuel Moto and tell them whats going on, they will direct you as well as help you set your PC if it needs an updated map. Its carb'd correct?
Old May 31, 2012 | 10:03 AM
steveleh97's Avatar
steveleh97
6th Gear
I just spoke with the dealer and it was like talking to a moron! Its like they have no idea, they basically told me that it will be time consuming to find the problem and that they will have to have my bike for awhile to mimik the situation "meaning: we are going to keep the bike and charge you $100/hr"......uuugggghhhh!
Old May 31, 2012 | 11:34 AM
steveleh97's Avatar
steveleh97
6th Gear
I have yet to change the fuel filter! The bike has 19,550 miles on it. It seems to be a sensor the way it is breaking up. I just unplugged the power commander and ran it stock and still have the same problem. That means the power commander is ruled out!
I did remove and clean both the cam sensor and crank position sensor but I do not know if either is bad.
Old May 31, 2012 | 11:49 AM
rh8234's Avatar
rh8234
I can't say for sure, but I think HD had some problems with their CPS's because between 2006 and 2007, there was at least two modifications to the replacement CPS's. The last digit of Part number changed to "a" and then to "b" . That usually indicates a design change, and my guess is that the sensors were flawed. Again - only uneducated guesses on my part and I am talking about the sensors for 06 sportsters. I am not sure if the sensor for your bike is the same part number. All I know is that after 4 years, the bike has run perfectly with the new CPS installed.
Old May 31, 2012 | 11:56 AM
soft 02's Avatar
soft 02
20k is the service intervle for the fuel filter. I'd try that first!
