SE back plate fitting problem ??
Old Jun 1, 2012 | 07:13 AM
rowle's Avatar
rowle
Default SE back plate fitting problem ??
Hi All,
Just trying to fit the SE air cleaner backing plate (29260-08) to my 2012 ultra and have a problem.
After taking off the original parts i am left with a black plate that holds a couple of plugs. Problem is, this plate is restricting the proper fitting of the backing plate as there is a gap between the throttle body and the backing plate. - see photo.
Are you supposed to remove this bracket ? - it does not say so in the instructions.
Thaks everyone.
Rowle - UK
Attached Thumbnails SE back plate fitting problem ??-cimg0135.jpg   SE back plate fitting problem ??-cimg0137.jpg
Old Jun 1, 2012 | 07:31 AM
TUCCI's Avatar
TUCCI
It looks like the plate needs to fit tight against the head. Are you able to remove the gizmo behind it .....instructions dont say anything does it?
Old Jun 1, 2012 | 07:41 AM
rowle's Avatar
rowle
Hi,
actually, just been searching the web and it appears you have to remove that plate ! - what a rubbish design from HD..........
Thanks
Rowle - UK
Old Jun 1, 2012 | 08:06 AM
Bushpilot's Avatar
Bushpilot
Yes the instructions say to remove and discard bracket. We have got around this by just cutting off the 2 outside tabs and leaving the bracket to hold the wires. Most air cleaner assemblies tell you to remove this bracket. Reason it is there is because the factory air cleaner is plastic where the SE air cleaner is metal and will hold the throttle body in place.
Old Jun 1, 2012 | 08:13 AM
vtwinbob's Avatar
vtwinbob
yes the plate has to come off, that's one of the reason's i went with A/N Big sucker. you don't have to remove the plate. just bolt it on and your good to go.
Old Jun 1, 2012 | 08:19 AM
vzts4q's Avatar
vzts4q
Actually it does tell you to remove it
Item 4 on the first page of the instructions have the following!
4. See Figure 1 and Table 1. Remove and discard support
induction module bracket (C).
http://www.harley-davidson.com/en_US...ts/-J04339.pdf
Old Jun 1, 2012 | 08:55 AM
FLPostman's Avatar
FLPostman
Default SE A/C fitting problem
Pretty sure there's a gasket that goes between the backing plate and the throttle body. If I remember it was at least 1/8" thick..That should close the "gap" between the two. And yes- the bracket held on with two screws has to come off, and the things that were cliped to it just zip-tied out of the way..
Just my .02cents..
Postman
Old Jun 1, 2012 | 09:03 AM
rowle's Avatar
rowle
Talking
Hi All,
thanks for the real fast replies.
ok - been down in garage and cut off the 2 outside lugs.
so now it all fits fine AND i still have the bracket to hold the electrical plugs.
Thanks Bushpilot for the idea !
You gotta love this forum
Rowle - uk
BlueDragon
Fuel Moto / Jackpot Mufflers
Sep 17, 2011 12:17 PM
Jamrom2
Jun 17, 2011 09:56 PM
MarkThomas
Apr 14, 2009 09:41 PM
Fogoms
May 11, 2008 10:21 AM
dawg
Sep 26, 2007 12:12 AM
