Changed over to floating rotors about a month ago. While working on the bike this week, I noticed that one of them was rubbing in one spot. It has a very slight bend in it. Only noticeable when the bike is on the lift. Is it OK to change only the one rotor since its so new?
Would you continue to ride as is.
If it is warped, you will feel it in your hands. What do you mean "rubbing in one spot"?
Yes, it is OK to change 1 rotor - especially if they are that new.
Exactly what I said, "rubbing in one spot"
If you put the bike up on the lift and spin the front wheel, it has more resistance against the brake pads in one area, so something is out.
GR, it's not grease, you can hear the pads rubbing against the rotor.
Im just gonna ride the **** out of it until I need new brakes and deal with it later.
