Wind causes dramatic difference in mileage?
Old Jun 4, 2012 | 07:37 PM
Harlie Rider's Avatar
Harlie Rider
Cool
I don't worry too much about miles per gallon as much as how many miles
to a tankful of gas.
It has been my experience that the less I ride, the longer a tank of gas will last.
For instance, if I ride to a bar and sit there all day, my tank of gas will last longer!
Old Jun 4, 2012 | 08:33 PM
Keithhu's Avatar
Keithhu
Interesting discussion!
In my case, the wind was pretty much head on.
Old Jun 4, 2012 | 09:22 PM
RK Joy's Avatar
RK Joy
That's a big difference. But if you rode one way with a headwind and the other way with a tailwind I can understand the change in MPG. The difference between 65 MPH and 80 MPH is more than you might think as well.
Old Jun 5, 2012 | 02:59 AM
Arizona's Avatar
Arizona
I had a major headwind for a few hundred miles coming south from Salt Lake City once on an Electra Glide and got 25 mpg at fill-up. So yes it can make a significant difference!
Old Jun 5, 2012 | 07:16 AM
grbrown's Avatar
grbrown
An elderly friend of mine and long time rider (no longer with us) had a favourite saying that there is nothing a bike likes more than a following wind! If you had been riding in the other direction your bike would have sailed along on the aroma from your tank. So you haven't had an unusual experience.
Current bikes have very high gearing, so with a headwind you were probably doing the wise thing maintaining a higher speed, to get the motor up onto a decent part of the torque curve. Much slower and your bike may have struggled, even got poorer mileage.
Old Jun 5, 2012 | 11:01 AM
Shredding rubber's Avatar
Shredding rubber
Wind plays a big role in respect to mileage. If your riding into a 30 mph headwind and you are doing 60mph that's equal to 90mph worth of wind resistance.
My bike got over 60mpg when I rode with a 50mph tail wind. I couldn't believe it.
On the way back I was lucky to get 35mpg,and had to stay in 5th because I almost had to wind it out when trying to maintain 70 in 6th.
I manage to average 42-45 mpg unless the wind is up.
Old Jun 5, 2012 | 12:13 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
Makes sense I'd say!
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old Jun 5, 2012 | 12:47 PM
btsom's Avatar
btsom
Air resistance changes by the square of the change in velocity. On a day with no wind, you get a certain amount of resistance at 50 mph. On another you ride at 70 mph into a 30 mph headwind generating a 100 mph speed through the air. The wind drag is now 4 times what it was at 50 mph with no wind. That extra resistance costs lots of gas.
I believe power enrichment is programmed into the fuel map, I know it is set into carburetors. When you ask for more than 75% of the available power, the fuel mixture is enriched for more power and to help cooling. Available power varies with RPM. To just pick some numbers, our engines may only develop 10 hp when at full throttle and held at 1000 rpm, perhaps 60 hp available at 3500 rpm at full throttle and full rated power at the RPM where the horsepower peaks. If you are cruising at 3500 rpm using 25 horsepower you are using a little less than half of the available power. Now, at the same speed/rpm, you climb a hill or get a strong headwind you may need 50 hp to maintain speed and RPM. 75% of 60 hp is 45 hp and you are asking for 50 hp with your throttle position. Fuel flow will increase proportionally until 45 hp and increase at a higher rate above 45 hp for power enrichment. Running at high speed into a strong wind gives you exponentially higher wind resistance AND if the power to do that exceeds 75% of the available, fuel flow increases non-proportionally for the power requested above 75%. Fuel economy tumbles drastically. Under this condition, cruising in 5th might save fuel.
I didn't mean to "build the watch", but perhaps this will help to understand why speed is expensive.
Old Jun 5, 2012 | 01:03 PM
Keithhu's Avatar
Keithhu
Ozark Azz
2014-2024 Touring Models
23
Dec 1, 2015 07:57 AM
roadrage12
Jun 12, 2014 08:08 PM
Foodog
May 2, 2010 05:25 PM
travroc
Jul 2, 2008 07:33 AM
misterkidgo
Apr 30, 2008 01:32 AM
