12v Power adapter in TourPak
Old Jun 5, 2012 | 01:33 PM
cfave's Avatar
cfave
Default 12v Power adapter in TourPak
I and a new owner of a 11 FLHTK and today I went to use the Power adapter for the first time to charge my cell phone while riding and it didnt work. Is there something Im missing or should it fire up as soon as i plug something in? I tried it while the bike was not running but had the accessories turned on and also when the bike was running.
Old Jun 5, 2012 | 01:35 PM
Scaredofrain's Avatar
Scaredofrain
Installed mine 3 weeks ago on an '07 Ultra. Power on run and acc. Have you checked the little fuse in the loom?
Old Jun 5, 2012 | 01:49 PM
vtwinbob's Avatar
vtwinbob
first check the fuse!! but more then likely the polarity is backwards on the power adapter you'll have to reverse it.
Old Jun 5, 2012 | 02:27 PM
Scaredofrain
Not sure on the FLTH bu,t on the Ultra you plug the power supply cable in the accessory plug of the wire harness and there's no possibility to switch polarity.
Old Jun 5, 2012 | 02:32 PM
davessworks's Avatar
davessworks
Make sure your plug isn't rattling loose. I've taken to using duct tape to secure my accessory plug into the outlet.
Old Jun 5, 2012 | 02:33 PM
vtwinbob's Avatar
vtwinbob
are you talking about the one under the seat?
Old Jun 5, 2012 | 02:42 PM
Scaredofrain
Just reading your post again Chris. Am I right in thinking the bike came with the power outlet installed? If so, it might be a non OEM. In that case you might be better of tracing the wire. All you have to do is take the seat off and check whether it is wired from the battery or from the wire harness. Obviously, if it is non H-D VTwinbob could be correct about the polarity. If it is non HD you better make sure that there is a floating fuse in the circuit too.
Old Jun 5, 2012 | 02:43 PM
Scaredofrain
Yes I am Bob, righthand side next to the battery so a little lower than just under the seat.
Old Jun 5, 2012 | 02:48 PM
vtwinbob's Avatar
vtwinbob
thought so, his is in the tour pak, when i fist read it i thought it was on the fairing, till i re-read it. they could have got the wires switched up when they hooked it up at the factory. that's why i suggested switching them and seeing if that worked.
Old Jun 5, 2012 | 02:54 PM
Scaredofrain
Understood Bob, the original plug looks like this one and cannot be reversed (unless wrongly assembled in factory)
