PC –V Excessive Trim Values?
Old Jun 5, 2012 | 07:14 PM
2007z71's Avatar
2007z71
Default PC –V Excessive Trim Values?
Just thought I woul check the Trim Values on my PCV today before a long ride tomorrow and I found some excessive trim values and I'm wondering what you guys think. Maybe they are not excessive?
Map originaly from FuelMoto only change is that auto tune has been running for awhile but I havnt accepted the trim values yet.
Old Jun 5, 2012 | 07:35 PM
11roadie's Avatar
11roadie
Everyone rides differently. Accept the trims and just ride it like you always do. Just make sure and save your original map for future ref. Got mine from FuelMoto also. I accepted the trims about once a week. My trims looked about the same at the start using the AT. My mileage was a bit low but now after about 500 miles it runs great and mpg is about 42. Enjoy your ride.
Old Jun 5, 2012 | 08:15 PM
2007z71's Avatar
2007z71
I havnt noticec any problems so I guess everything is cool.
Thanks for the reply!
Old Jun 6, 2012 | 03:15 AM
Watch Guy's Avatar
Watch Guy
Default U may want to keep an eye on those trims.
Try re installing the original map and see if those trim values continue. If they do then you could try changing the AFR settings a little. It looks like your map may be set a little too lean and that's why trims are so high because the AT is compensating to try and match the AFR to the map setting. That is unless this is the first time you've checked the trims.
Old Jun 6, 2012 | 05:02 AM
luc.who's Avatar
luc.who
I would make sure I have the base map saved, then accept these values, they don't look too bad, there are limited areas where the AT is adjusting.
Another option you have is to not accept your trims and change the adjustment to 5% instead of 20%. That way you can accept smaller trims to see if there is an issue. I like to do this (ok used to do this) and save a monthly map.
Old Jun 6, 2012 | 03:30 PM
62hdbiker's Avatar
62hdbiker
They don't look bad to me. Do you have a pic of AFR values?
Old Jun 6, 2012 | 03:55 PM
Bowhunter61's Avatar
Bowhunter61
Originally Posted by Watch Guy
T It looks like your map may be set a little too lean and that's why trims are so high because the AT is compensating to try and match the AFR to the map setting. That is unless this is the first time you've checked the trims.
Not really true, his trim values are negative so it looks like it is actually trying to lean it out some from the base map. So his base map may be a little rich compared to the AFR values he has.
I have adjusted my base map and put in higher AFR's in my cruising range and the AT is now adjusting, so I am seeing some trim values in the -20 up to -30 range.
So it depends on the original base map and what the AFR's are set too, and that will determine how large of an adjustment the trim values will try to make.
It could be you got a rich map from FM.
Old Jun 6, 2012 | 04:00 PM
rberni's Avatar
rberni
Didn't know there was a such thing as excessive trim
Old Jun 6, 2012 | 04:42 PM
2black1s's Avatar
2black1s
I've done so many trim runs on my bike that most folks would consider me nuts. I have hundreds of these saved on my computer.
In the tweaking of my base map(s) I would target trims of 2% or less throughout the entire map and would validate the map by back-to-back test runs (approx 20 miles minimum) with nothing more than my target 2% trim.
2% is a very optimistic target and probably much closer than necessary but that's what I shoot for anyway. You have to do a lot of hair splitting to get there. When developing the maps, 3% or 4% is probably a more realistic target to shoot for and then over time a few trims as high as 5 or 6% are not uncommon, but the majority of trims should be smaller - like 3% or less.
Any double-digit trims are strong candidates for tweaking the respective fuel table cell in my opinion.
And one other point, once I got my map where I wanted it, I zeroed out the AFR target for the 2% TP column. What that does is in effect takes the autotune out of the loop at that throttle position. The reason I did this is because the autotune does not work very effectively and cosistently at 2% throttle. You'll be chasing wildly swinging trims there forever if you don't.
Old Jun 6, 2012 | 06:43 PM
Bowhunter61
Have you done any comparison on trim values between temperature differences? Reason I ask is I ride to work in the morning (could be anywhere from 40-60F) and then come home when it is anywhere from 75-95F. I was assuming the 2% limit on the trims wouldn't be enough to adjust for this, but I'm not sure how much the temperature and affect on air density would change the trims.
I have found this out the hard way, I chased the 2% column for some time even set at 10%
