Front wheel trembles.
Old Jun 10, 2012 | 07:33 AM
zorrow7's Avatar
zorrow7
Stage II
Default Front wheel trembles.
I nneed help. Front wheel shakes or trembles when i remove my hands off the handle bars at low speeds. Please help ,zorrow7
Old Jun 10, 2012 | 07:45 AM
08egstd's Avatar
08egstd
I'm no expert but I would look for a balence weight that might have fallen off or somthing wrong with the tire. Hope you find the problem, ride safe
Old Jun 10, 2012 | 07:47 AM
08egstd's Avatar
08egstd
I should have added welcome to the forum!!
Old Jun 10, 2012 | 07:51 AM
lionsm13's Avatar
lionsm13
Need more information
Old Jun 10, 2012 | 08:12 AM
n8dc's Avatar
n8dc
3 things... tire,tire balance, neck bearing adjustment.
Old Jun 10, 2012 | 08:33 AM
Road Ranger's Avatar
Road Ranger
Check tire air psi...should be around 38 - 40 psi
Old Jun 10, 2012 | 11:08 AM
ctso030's Avatar
ctso030
does the vibration go away over 50mph if so could be balance, how many miles on the tire, jack up the front end just off the ground and spin the wheel see if its round. also check for play in the bearings while it is jacked up
Old Jun 10, 2012 | 11:11 AM
Scaredofrain's Avatar
Scaredofrain
+1 on the neck bearings.
Welcome to the forum. Don't forget to introduce yourself.
Old Jun 10, 2012 | 12:50 PM
fjoh's Avatar
fjoh
My bike (2010 FLHX) was doing that but it was only around at 30mph coasting.... So I didn't let it bother me.. Then when I changed my front tire (stock dulop) it (the wobbling) disappeared completely.
So it maybe your tires causing it...
I also have Metz ME880 rear tire now and I like it better than the stock dunlop. I will be putting on a ME 880 in the front when it's time.
Hope this helps.
Old Jun 10, 2012 | 01:49 PM
WanaRyd Wheels's Avatar
WanaRyd Wheels
Sponsor
Yea we def need more information here, couple be a number of things, welcome to the forum BTW
__________________
WanaRyd Motorcycle
1-888-926-2793
