Ahhhh, a dreaded oil question :(
Old Jun 11, 2012 | 05:48 PM
bklynbob's Avatar
bklynbob
Some oils have better additive packages than others. I have never owned an air cooled bike that didn't have an oil cooler and thermostat. I think it's a must have if running dino oil. check this out:
http://www.thunderpress.net/Articles...otorhead_Memo/
Old Jun 11, 2012 | 06:11 PM
Potato_Potato's Avatar
Potato_Potato
Originally Posted by steelerdude1
I am about due for an oil change, and I am switching back to Dino Oil, (Amsoil) synthetic is too noisy on the top end.
Can I just buy some good old 20W50 @ Walmart? do I have to use non energy conserving like I did with my metric, or doesn't it matter since it doesn't lube the clutch.
Sorry for the dreaded Oil question, but I need to know.
To my knowledge Walmart does not carry Dino oil in 20W50.
They have Mobil 1 V-Twin in 20W50 and Mobil 1 15W50 both are synthetic.
Old Jun 11, 2012 | 06:20 PM
steelerdude1's Avatar
steelerdude1
You may be right, It's been pushing 10 years since my last air cooled bike. I used to buy my 20w50 at wallyworld, but they may not have it anymore. If not I will go to Advanced Auto or Autozone.
Old Jun 11, 2012 | 06:24 PM
Dew Me's Avatar
Dew Me
Quite an article! Did a little looking and he seems to be well published as well. Flash points were interesting as well as true synthetics. Sure makes Redline sound like the best. But even though it base is considered the best protection from high temp operation 2 have a higher flash point.
The destruction of additives and oil lasting forever are very good points as well. Seems like we should all have machines in our garage to add the additives back into our oil. Or maybe some additives actually add it back in for us? No more oil changes would be nice.
Either way, it sure reinforces using synthetic in my bike. Makes me think a lot harder about a better synthetic than S3 too.
Old Jun 11, 2012 | 06:27 PM
Mikey 1450's Avatar
Mikey 1450
Default motor oil
Google search "More than you ever wanted to know about motor oil" by Ed Hackett.
He explains it as easy to understand as I have read. Lots of good info in the article too!
Old Jun 11, 2012 | 06:43 PM
qtrracer's Avatar
qtrracer
Keep in mind that some dino oil flash points are higher than synthetics, yes Mobil 1(V-Twin) and Amsoil(MCV) even, VR1 20w/50 dino is higher than either. Just because the public has been spoon fed the idea that syn oils handle heat better than dino oils doesn't make it true of every dino oil. Do your own research and find out for yourself, don't take my word or anyone else's word for it. I will say that my research has led me to the conclusion that Redline handles the heat the best. But some Redline oils have higher flash points than others and thats true of every oil companies products.
Old Jun 11, 2012 | 06:50 PM
Dew Me's Avatar
Dew Me
Yeah, I'm not big on blindly taking peoples word on things. That's why I Googled the guy that wrote the article. Sure wish there wasn't so much controversy on the subject. It's like talking about religion.
Old Jun 11, 2012 | 07:57 PM
Shredding rubber's Avatar
Shredding rubber
Walmart has castrol gtx in the 20w-50 flavour. Here anyway.
As far as oil goes a name brand,changed at proper intervals will help your bike live a long life.
The whole mineral vs synthetic has so much half truths and utter nonsense it's tough to get it all straight. I have used oil analysis' done on pennzoil 20w-50 and amsoil v-twin so I could cut through the junk and get real world answers.
Dino protects just as well as synthetic however synthetic lasts longer due to the fact it's pure,with no contaminants.
The more slippery nonsense coupled with the once you switch to syn you can't use mineral anymore is another falacy.
Try red line if top end noise was your issue. It's great stuff. I just put royal purple auto 20w-50 in mine and top end noise is almost non existent.
Old Jun 11, 2012 | 08:52 PM
RK Joy's Avatar
RK Joy
I decided to try synthetic on my last bike with the TC88. The bike had an oil temperature gauge that showed 15 degrees cooler, consistently with the synthetic. That spoke volumes to me about reducing friction so I stayed with synthetic. Switched the RK over at the 1000 mile service.
Old Jun 12, 2012 | 01:45 PM
mike_oh's Avatar
mike_oh
I am using Red Line 20/60 and am very happy with it. Top end is very quiet and in my hot climate it does the job for me. Have used Amsoil and Mobil 1 before.
