Knock, knock
Old Jun 16, 2012 | 02:01 PM
RoadHog659's Avatar
RoadHog659
Default Knock, knock
2009 Ultra -- So the intermittent squeaking is probably caused by brake dust, but what might cause my front brake to "knock" when I apply the front brake? One knock right when I squeeze the brake lever. Just started noticing it today on a ride without my helmet, so I don't know how long it's been making the knock-noise.
Old Jun 17, 2012 | 07:50 AM
RoadHog659's Avatar
RoadHog659
Never mind. Did a search on front brake "clunk" and found some discussion on floating discs and brake pad noise. Gonna check both out, but apparently the knock/clunk is pretty common and doesn't affect braking. 1st time I heard it though it had me a little concerned.
Old Jun 17, 2012 | 08:46 AM
Lowcountry Joe's Avatar
Lowcountry Joe
I have floating rotors, no knock. Might want to do the following:
-Remove the perforated caliper cover
-Make sure the pad pins are seated properly with safety clip installed
-Make sure the pad spring, which serves as an anti-rattle device, is there and firmly seated (located under the pads)
-Make sure your caliper mounting bolts are tight to torque specs
-Make sure you have not picked up a small pebble that has lodged in the caliper
Good luck tracking down the knock.
smithbrl
Aug 4, 2020 07:32 AM
kelton3
Jun 10, 2009 09:25 AM
zenwarrior
May 25, 2007 04:48 PM
69Shark
Feb 25, 2007 09:45 AM
HDF Tech
Jun 28, 2005 12:49 PM
