Rear brake problem I think . . . . . .
Old Feb 22, 2007 | 10:25 PM
69Shark's Avatar
69Shark
Default Rear brake problem I think . . . . . .
Hey all,
I have a 2002 FLSTCI bought in December. Been riding it daily except for the snow and ice.
The rear brake makes a vibration noise when I brake gently to a stop. Only makes the noise when just before stopping at like 5 mph or so. If I brake hard it makes almost no noise.
I've done the basics. I replaced the pads, checked the brake fluid, made sure all the bolts are tight, and that the rotor feels smooth. Heck, I even hit the brakes while sitting and watched all the brake lines incase there was movement. Nothing.
Braking works great. Stops predictably and nicely. Just rather loud sometimes. The bike has about 14K miles on her now. Hmm, now I have to go lokk at the miles . . .
I'm now at a loss. Only thing left is to completely bleed the system and replace the fluid. Well, that I can think of.
Any ideas?
Thanks in advance.
Scott
Old Feb 22, 2007 | 11:56 PM
HD7585's Avatar
HD7585
Default RE: Rear brake problem I think . . . . . .
Remove the caliper bolts/pins..........clean and regrease them. If they are binding..........the pads wont hit the rotor evenly and will vibrate...........causing the noise
Old Feb 23, 2007 | 12:20 AM
69Shark's Avatar
69Shark
Thank you.
Can I assume you mean the two pins that hold the brake pads in place?
Then could I assume that the brake pads are sliding across the pins unevenly thus the need for lube and reduction in noise?
Maybe I should soak them in carb cleaner so they are clean and then lube them?
Makes a lot of sense to me and they WERE NOT lubed up when I pulled them out!
Again, thanks!
Scott
Old Feb 24, 2007 | 04:16 AM
Oldtimer of NM's Avatar
Oldtimer of NM
I think he means the bolts that hold the caliper in place. These are normally shouldered bolts so that the caliper can move a little and follow the rotor.
Something worth trying, remove the caliper and, with a relatively fine file, put a slight chamfer on the leading and trailing edges of the pads. Since this stops drum brakes from doing pretty much the same thing, it will probably work on disks too.
It's a long shot, but, if you bought the bike used, take a close look at both sides of the rotor. If the previous owner had the rotor turned, it is possible they left a spiral "thread" on the surface. this will tend to pull the pad up or down until the pad snaps back with a very noticable thump.
Old Feb 24, 2007 | 03:20 PM
69Shark's Avatar
69Shark
Thanks OldTimer but HD7585 hit the problem dead on! The problem has been completely eliminated!
Thanks for both replies!
Scott
Old Feb 25, 2007 | 09:45 AM
billvaughn's Avatar
billvaughn
That's what this site is all about...Knowledge is power. Glad to see it was an easy fix and didn't cost you anything but a little time.....
[IMG]local://upfiles/2670/4415AA4DA1BB4C9591DD0C0E7D0B1C6A.jpg[/IMG]
harleyjth
2014-2024 Touring Models
May 13, 2014 11:00 AM
SE11
Aug 31, 2013 12:00 PM
SunRa73
Sep 27, 2008 10:46 PM
zenwarrior
May 25, 2007 04:48 PM
dakotacrk
Apr 20, 2006 05:08 PM
