Front Brake Squealing while riding...
Old Aug 29, 2013 | 07:35 PM
SE11's Avatar
SE11
4th Gear
Default Front Brake Squealing while riding...
The front brake on my 2010 Fatboy is making a little noise when I am riding however if I apply the brake the noise stops completely. What could be the cause of this? I bled all the brake line and added in new brake fluid and it fix the majority of the noise but I still have it happen from time to time. I have had stock HD pads and stock rotors and now I run lyndall pads with a new set of rotors and no matter which set up I had noise. This is something I would like to get fixed as its just kind of annoying. I noticed the that the brake pressure didnt seem constant when I was riding but after bleeding the brakes it seem much better. Any advice would help.
Old Aug 29, 2013 | 10:05 PM
Mikey8717's Avatar
Mikey8717
I had the a similar thing happening to me after i changed the rotors on my bike. idk what caliper you have but i had to replace some o-rings in mine and lube them so that the pins would slide properly. but i have the old style caliper. I don't know if this is going to help but that's the story i have. GL
Old Aug 30, 2013 | 04:36 AM
Rodzilla6's Avatar
Rodzilla6
Check your wheel bearing...that was the hint mine was failing...for the first time...They are garbage after 08...
Old Aug 30, 2013 | 09:41 AM
Mike NY's Avatar
Mike NY
I had the same issue when I replaced my Brake pads with Lyndalls and a new rotor.
It went a way after a bit of riding but I imagine it was from the pad dragging a bit on the new rotor. Once things broke in a bit it's been fine.
That's my experience but you should check into it since your brakes are a fairly important part of the bike,
Mike
NY
Old Aug 30, 2013 | 10:16 AM
Yankees's Avatar
Yankees
I had the same situation about a month ago and it bugged the hell out of me. For me a was sort of a metallic squeal, hard to explain but different than a normal brake squeal I ended up just breaking down the caliper, cleaning all the parts and lubing it up real good. Squeals gone and my sanity has returned.
Old Aug 30, 2013 | 11:41 AM
lionsqrne's Avatar
lionsqrne
Pull the brakes off and remove the pads. Clean with brake parts cleaner. Apply a small amount of brake grease to the lip of the caliper plungers. Re-assemble. Should be good to go. May have to repeat again in the future.
Old Aug 30, 2013 | 11:52 AM
ynots's Avatar
ynots
As your pads wear the pistons in the caliper become more exposed. When you replace the pads the pistons are pushed back inside the calipers and any corrosion on the piston may prevent it from retracting properly. Hence above post: Applying a small amount of brake grease to the lip of the caliper plungers can help
Old Aug 31, 2013 | 12:00 PM
oct1949's Avatar
oct1949
When U replace the pads,, MAKE sure who-ever does it cleans the pistons in Ur calipers.
They can stick and the pads will put pressure against the rotor if not.
Harleyforever
Apr 18, 2016 08:52 AM
69Shark
Feb 25, 2007 09:45 AM
SPECIAL ED
Aug 12, 2006 08:18 PM
dakotacrk
Apr 20, 2006 05:08 PM
flying12
Apr 9, 2006 02:09 PM
