Adjustable or not?
Old Jun 17, 2012 | 12:51 AM
jerren25's Avatar
jerren25
Default Adjustable or not?
I am looking into getting some batwing air deflectors and fork baffle. I am wondering if there is any big difference to getting the fixed or adjustable. I live in the northeast so it does not get that hot up here. I would rather spend 40 bucks not 100. Thanks for the input.
Old Jun 17, 2012 | 01:14 AM
W.P.'s Avatar
W.P.
I don't open mine unless it's really hot because when there open it causes more wind noise that bothers my ears (no helmet) but the difference is very noticeable.
Old Jun 17, 2012 | 01:20 AM
mkguitar's Avatar
mkguitar
I look at the air management thing differently than most riders- that probably means I am wrong.
The bigger the hole you try to punch through the air ( the larger the profile of the fairing/windscreen/ deflectors etc.- then the larger the low pressure zone in the cockpit.
air rushes in from the sides and below to fill that zone- and this is the "buffeting" that some riders find annoying.
I use the adjustable fairing deflectors to direct controlled air into the cockpit- this helps to decrease the pressure differential- and less air wooshes in from the sides and below.
some riders are trying to find still air- they won't until they end up in an enclosed box.
I try to find ways to work with the air to give a comfortable ride.
Mike
Old Jun 17, 2012 | 05:56 AM
jerren25's Avatar
jerren25
bump.
Old Jun 17, 2012 | 06:00 AM
Iceman24's Avatar
Iceman24
Agree w/mkguitar...I went w/adjustable wings so you can adjust accordingly. Also, added lowers, fork baffle + taller shield. Between all four accessories/upgrades, my FLHX is pretty comfy...good luck!
Old Jun 17, 2012 | 06:33 AM
Lowcountry Joe's Avatar
Lowcountry Joe
You can see in this photo my wind deflectors on each side of the faring. In hot weather, I keep them adjusted as you see them to force air into the cockpit area for cooling. I close them in the winter and when temps are below 55. They work well for me.
Old Jun 17, 2012 | 06:51 AM
98Ultra's Avatar
98Ultra
Adjustable, that way you have something to adjust. Duh. Really, I do direct the air when it gets hot and close them when it isn't.
Old Jun 17, 2012 | 09:28 PM
hardskull's Avatar
hardskull
I love the adjustable wings. I found that riding in winter, you can actually flip them around backwards, almost completely, the negative pressure pulls a little of the engine heat up towards you. Otherwise, normally tilt and adjust to direct air flow on you. sometimes it's like riding in a convection oven, but still a good option to have.
Old Jun 17, 2012 | 09:38 PM
jerren25's Avatar
jerren25
Installed the fork baffle and the adjustable wind deflectors. What a difference, I'm pumped about the ride now.
Old Jun 17, 2012 | 09:46 PM
Wv7o's Avatar
Wv7o
The adjustable deflectors mount with 4 bolts to the fairing, the non adjustable ones use 3 bolts to mount to the fairing, they are not interchangeable.
The OP has no choice but to get the adjustable ones (if getting them from HD) as a 2010 FLHX uses the 4 bolt mounting system.
I am not sure if 4 bolt non adjustable deflectors are available in the aftermarket, at least when I got mine they were not.
