How much air in rear shocks?
Old Jun 20, 2012 | 10:40 PM
tom lipke's Avatar
tom lipke
Default How much air in rear shocks?
I have an 01 electra glide how much air for single and 2up?
thanks
Old Jun 20, 2012 | 10:43 PM
pswomack's Avatar
pswomack
I believe 40psi is max air for the rear shocks on your bike, I would try 20 for both single and 2 up and see how it rides/handles.
Old Jun 21, 2012 | 06:13 AM
RK Joy's Avatar
RK Joy
I run 35-40 for 2 up. I usually leave them set that way even when I ride alone. Seems about right.
Old Jun 21, 2012 | 06:14 AM
Iceman24's Avatar
Iceman24
Weight (rider + passenger) & gear make a difference - care to supply the #'s???
Old Jun 21, 2012 | 06:46 AM
Dawgtraxx's Avatar
Dawgtraxx
Never ride two up, wife rides her own..run about 23 psi..seems fine
Old Jun 21, 2012 | 09:17 AM
tom lipke's Avatar
tom lipke
do the earlier bikes 01, 02 take less air than the later models?
Old Jun 21, 2012 | 09:21 AM
Stash905's Avatar
Stash905
Max pressure for an 01 is 30. I would start around 20 to 23.
Old Jun 21, 2012 | 09:24 AM
roadking2014's Avatar
roadking2014
the older air shocks used lower pressure than the newer ones. I had an older road king and ran 5 single and 10 two-up.
Old Jun 21, 2012 | 09:40 AM
SinisterFLHTCI's Avatar
SinisterFLHTCI
I run 20#s with or without my better half. I'm 235#s and shes about 120#s.
Old Jun 21, 2012 | 10:47 AM
XARAN's Avatar
XARAN
thanks
There is no "set" pressure. Try different pressures and see what gives you the best ride based on your needs. its very subjective. Anything from 0 to 40psi is correct if it makes you happy.
When I had the OE shocks on my bike I ran 12-16 solo and it was Ok, almost the same even if I ran 0 only difference was on the bigger bumps it bottomed with no air, but on the road it was fine. Some of the guys I ride with run 20-35 psi solo and like it. So you need to try out different pressures and decide.
