bike jack failed
Old Jun 24, 2012 | 07:18 PM
Sparky73's Avatar
Sparky73
I have the red/black Craftsmand jack and it won't slide out from under the bike on the jiffy stand. I'm assuming your jack was inserted from the right side and that she has let fully released the jack.
All I do is stand on the right side, pull the bike up a little with the right handlebar and the jack slides right out. Don't have to pull it all the way off the jiffy stand, just pull enough so the jack will slide. If she loses her grip, it'll go right back onto the jiffy stand.
Also recommend that she go to Sears with the receipt and explain her situation to the Tools Manager or the Store Manager before your warranty is up. They should take her name and honor the warranty when you're able to take it in. if not, post it here and we can all start shopping elsewhere for tools!
Old Jun 25, 2012 | 05:24 AM
riteway's Avatar
riteway
Hey if Sears wont HONOR the warranty...Buy another Yellow Jack and return the defective one.
I have a Yellow jack and i am very happy with it... Now the red one was a POS.. :-(
Old Jun 25, 2012 | 06:18 AM
RK Joy's Avatar
RK Joy
I have the same jack. Sometimes I forget that you have to manually disengage the lock mechanism to let the jack go down. I have had good luck with mine in the 5 or 6 years I have owned it.
Old Jun 25, 2012 | 07:24 AM
47Norton's Avatar
47Norton
I have the red craftsman jack and it's possible when you engage the lock to only catch it on one side. I bent mine around a little to make them both engage evenly. I still check it carefully when letting it down on the locks. Not sure, by your description, if that might be your problem. I'd say she needs some help from someone familiar with these jacks.
Old Jun 25, 2012 | 07:46 AM
eathomps's Avatar
eathomps
Where in Alabama is it? If you're near Huntsville I could go over and get it off the jack.
Old Jun 25, 2012 | 08:14 AM
harley_badboy's Avatar
harley_badboy
Originally Posted by ndnguyd
If she has help, try jacking bike up again with foot pump, and than releasing the valve again. Once bike is on kickstand, have her step on the jack or put more pressure on jack. It will bleed off enough to pull out from under bike. If that makes sense.
What I do ^
Old Jun 25, 2012 | 01:01 PM
brettnbama's Avatar
brettnbama
I appreciate the offer, but I actually moved up around Atlanta before I deployed. The locks on the yellow jack are automatic. I thought I released the pressure but I guess not. She said there is something broken on the lock. I will have her go by Sears and talk to them, thanks guys...
Old Jun 25, 2012 | 01:05 PM
mtclassic's Avatar
mtclassic
the clip that holds the locks is cheesy at best.
Old Jun 25, 2012 | 01:16 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
Originally Posted by Stiggy
A neighbor or friend might get a car jack under the right side frame opposite the front highway peg and lift the bike against the side stand to raise the frame up enough to get the jack out of there and back to
+1, that was my idea too. Try and lift it with another jack of some sort enough to get the other one out. good luck!
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
JImf7186
Dec 28, 2017 09:13 AM
jsimo7
Mar 9, 2010 07:09 AM
2WheelThrill
Mar 5, 2010 01:57 AM
GodFather
Jul 1, 2009 02:46 PM
Delrob
General Topics/Tech Tips
Jul 10, 2006 09:22 AM
