Need Help With TTS Base Map
Old Jun 27, 2012 | 06:55 AM
1sweetglide08's Avatar
1sweetglide08
Default Need Help With TTS Base Map
I have a TTS MasterTune and tuned my bike 2 years ago. So I'm a little rusty. Can someone help me with the base map I should use. This is what I have on my bike and want to tune. 2008 FLHX 96ci motor, SE 255 cams, SE Ventilator AC and V&H Pro Pipe. If I install a can map will I be close enough to ride until I read up on the V-Tune process? Thanks for any help.
Old Jun 27, 2012 | 07:16 AM
SmittyFXDL's Avatar
SmittyFXDL
All depends. I have a 10 flhx, dragula pipe and se ac with tts and I had to use vtune. Had decel pop on canned map. Maybe someone that has a configuration close to yours can chime in and share their map with you.
shootist57
The Dyno Room
May 9, 2017 10:33 PM
Indy Road Dog
Mar 13, 2016 03:36 PM
JAKE 2544
May 6, 2013 02:41 PM
VETERAN75
Jul 25, 2010 07:44 AM
Herr Monk
VRSC Models
Feb 13, 2008 07:36 PM
