Rock in belt so should I change the gearing
Old Jul 5, 2012 | 02:37 PM
Mike's Avatar
Mike
Originally Posted by B20
Well The reason for pulley change is damage from the rock it's bad pencil size mark in pulley so new belt will just get damage and fail soon
Yes, if you've got a visible chip in your wheel pulley, it needs to be replaced. If the rock in the belt chipped up the wheel pulley, the trans pulley also needs to be inspected for damage, and probably also replaced. If the trans pulley needs to be replaced because it's damaged, then now is the perfect time to change your gearing. Your logic is correct.
I think a 30t trans pulley combined with your stock 68t wheel pulley is the perfect final drive gearing for these heavy bikes. That's what I'm running on my bike, along with a pretty stout 107 motor, and the bike finally feels like it's got decent acceleration. I can cruise all day on the freeway at 75+ mph at just over 3000 rpms. (at the 70 mph speed limit, I'm doing around 2800 rpm).
It's a great upgrade, not at all expensive if you're doing the work yourself. If you're paying labor cost to have your pulleys changed, you want to think carefully about what gearing you actually want in your bike.
Old Jul 5, 2012 | 07:16 PM
racklefratz's Avatar
racklefratz
The missing link in all this is that nowhere in this thread has the OP disclosed why he believes "re-gearing" is necessary, if at all. Everyone chiming in with their opinions on if re-gearing is necessary/appropriate/whatever...yada, yada, yada.... is fine, but the OP is the court of final opinion - his counts more than anyone elses.
It's time for the OP to step up and clearly state if he believes re-gearing is required, and if he does, asking for opinions here is fine. But, if we don't have that information, all the speculation is pointless.
Old Jul 7, 2012 | 02:08 AM
B20's Avatar
B20
I need to be in 6th gear at a earlier point like 3-4 mph sooner
Old Jul 7, 2012 | 06:33 AM
dc1450's Avatar
dc1450
I don't know why OP wants to gear down, but from the last post though it's on top, he wants to be in 6th sooner and gearing down will accomplish that. It would also bring first down which in my opinion is also too high, they suck in traffic and low speed maneuvers compared to the 5 speed. I think you're on the right track, as long as you need to replace the pullys anyway.
Old Jul 8, 2012 | 01:09 AM
B20's Avatar
B20
Correct I was out on my buddies 04 nightrain tonight damn 5spd bikes are geared better
Old Jul 8, 2012 | 01:11 AM
Shredding rubber's Avatar
Shredding rubber
I considered a 30 tooth trans sprocket change. It would get the rpms into the motors sweet spot sooner(like 70mph instead of like 76 in 6th) until I went 106.
Not considering the gear change anymore
Old Jul 8, 2012 | 01:05 PM
racklefratz
But before you make the jump, make sure you understand there's no free lunch. You gain something somewhere, but you give up something elsewhere.
Lower the gearing and you'll lower all your shift points. You'll get off the line in 1st easier, and you'll maybe get into 6th a little earlier. But.....you'll probably give up some fuel economy, and, at the end of the day, no matter what your gearing is, when you stay in the engine's power band, the rest doesn't matter all that much.
IMO, the HD engineers probably spent a lot of time deciding how to set the bike's gear/drive ratios, based on a lot of stuff we don't even know about. I suspect it's optimized for normal riding, and any change lessens that optimization is one way or another. A decision to modify the factory gearing on an otherwise stock bike is essentially saying you know more than the designers - a pretty bold statement.
Old Jul 8, 2012 | 01:24 PM
Tee Bagger's Avatar
Tee Bagger
If you are able to utilize 6th gear more your mileage should actually increase, maybe even pay for itself over time. These same engineers designed the suspension, seat, handlebars...etc. Nuff said...
Old Jul 8, 2012 | 04:01 PM
bklynbob's Avatar
bklynbob
Really ,giving up 2-3 mpg to have a more responsive bike ? You can have your cake and eat it,too. It's called a Baker DD7
Old Jul 8, 2012 | 08:04 PM
racklefratz
No...not 'Nuff said. That's total bullshit. You can put the bike into 6th gear at any speed you want. But there will be some speed below which, the engine will work harder to achieve the same speed. That's the point at which you will have lost your fuel economy.
