engine light
Old Jul 5, 2012 | 08:59 AM
StreetGlidinFreak's Avatar
StreetGlidinFreak
Default engine light
Ok.... I crank the bike.... it fires up, the engine light is on.. I notice the volt guage is right under 12.... I rev it up a little... the volt guage goes to 14.. light goes out.... stays at 14 through out the ride.
I replaced the battery when I noticed it the first time, it would pull down to 10 v and a touch slow to start.. pulled and checked battery with a load tester.. went to yellow meaning it was on it's way out... I put the new battery in... fires up better.. still the same thing with the light and reving it up....
any body else run into this?
Old Jul 5, 2012 | 01:24 PM
gmurdock's Avatar
gmurdock
I have an 09 SG. Just had to replace the battery about a month ago. Just started noticing the when I turn my bike on the engine light goes out when the fuel pump is ready, starts up fine, then about 2 seconds latter the engine light comes back on for about 5 seconds? Never saw this before?? Will try reving it up tonight.
Old Jul 6, 2012 | 11:19 AM
StreetGlidinFreak
Well, sounds like we may have possibly have the same problem....
Now anybody had this problem and figured out what it was???
The way my luck runs, I figure when we head out on our 3 day ride at the end of the month, that will be about the time what ever it is finally lets go and shows it self.
Old Jul 6, 2012 | 11:48 AM
KeeBee's Avatar
KeeBee
Maybe your voltage regulator?
Old Jul 6, 2012 | 11:50 AM
Ghosttrain1's Avatar
Ghosttrain1
From: Austin, San Antonio, Canyon Lake, Houston, Palestine, Texas
Mine did the same thing right after the voltage regulator was replaced. Replaced the stator and now it doesn't do it anymore.
Old Jul 6, 2012 | 12:09 PM
StreetGlidinFreak
Yeah... .stator is what I was thinking also...... Or was trying not to think. Hopefully since it charges 14 as soon as you rev it and stays there, it will work on my ride.
Old Jul 6, 2012 | 01:13 PM
djpfd12's Avatar
djpfd12
Stage III
herd there was a recall coming out for the 2012 street glide for the voltage regulator. My engine and battery light came on the other day. Call the harley dealer and said they just got a service bulletin. Now my bike is parked till Wednesday first day they can get me in and fix it.
Old Jul 6, 2012 | 01:57 PM
Krutch's Avatar
Krutch
From: somewhere in "The Peoples' Republic of Illinois
The light coming on is a signal to check for a service code. Ought to be instructions in your owners manual. Get a service manual, if'n ya don't already have one, and sit down and read all about it. May save ya headaches later.
Old Jan 12, 2013 | 05:58 PM
road glide o8's Avatar
road glide o8
a couple times recently...my battery and engine light have come on few times(first ride in a month) whenever it does it battery guage drops from just under 14 to about 11.
then after few minutes goes back to normal????
any ideas ?
Old Jan 12, 2013 | 06:21 PM
HAWGMAN's Avatar
HAWGMAN
Sounds just like the issue that I had last summer and it turned out to be the voltage regulator on my 2007 FLHTC. I had the battery replaced, then the voltage regulator and things worked out well until I took it on a trip to the Ozarks and the light came on again, then went off. I stopped at Toad Suck Harley Davidson and they did a system check and said all is well. On the way back to Mt. View the light came back on and stayed on. I put it on a trailer and came back home. Turned out to be the new voltage regulator had went bad. Other post on this forum said there was a problem with some of the replacement regulators as well as the regulators on the newer scooters.
Don't wait till the second day of of a three day trip to address an issue that is going on before you leave home.
Happy Trail's
