what are these pluge??
Old Jul 6, 2012 | 05:02 PM
Firechaser1141's Avatar
Firechaser1141
Originally Posted by joflewbyu2
They are for other markets headlights that include a running light inside the reflector. I would not use them to power spots unless LED as the current draw might be to high for that thin gauge wire.
ohh ok sounds right i was planning on using the one with the red cover on it for the spotlights had the ignition when checking
Old Jul 6, 2012 | 09:49 PM
vangasman's Avatar
vangasman
The orange wire with the white stripe is the one that provides power when you install Harley's kit. It is the same gauge as the stock set up. It does look a little weak but I assume they have a relay somewhere and I haven't had a problem and I leave mine on all the time since a near miss with a car.
Old Jul 7, 2012 | 06:25 PM
jdlogan's Avatar
jdlogan
The wires are there for the Harley HID headlight option, that nobody ever uses. I use mine to power the GPS.
Old Jul 8, 2012 | 04:25 PM
Firechaser1141
so this wire should work for power for spotlights
Old Jul 14, 2012 | 01:28 PM
vangasman's Avatar
vangasman
If you don't already have spots I can't say. I'm sure that it runs through a relay and thats why the wires are such small gauge.
B-RAD22
Electrical/Lighting/Alarm
May 3, 2021 02:07 PM
todd-67
2014-2024 Touring Models
Jun 24, 2016 06:08 AM
mech-a-nic
Aug 6, 2010 09:20 PM
AlCherry
Feb 14, 2010 03:02 PM
Doc
Nov 23, 2006 02:31 PM
