Need PCV Map
Old Jul 9, 2012 | 12:20 PM
vickers1's Avatar
vickers1
Originally Posted by VTGlideRider
This may be a silly question, but did you try looking for a shop who would do your cams AND deal with the PC-V instead of just going to the dealer who is trying to "steer" you into buying an SE tuner?
I realize tuners recommend the device they are most comfortable working with, but you may have an indy shop or another dealer within a reasonable distance that will accommodate what you have.
I wanted a Harley dealer ONLY for bike warranty purposes.
Old Jul 9, 2012 | 12:26 PM
vickers1's Avatar
vickers1
Originally Posted by WireDawg77
Why would you get cams installed at the dealer??? They are going to rape you on labor! Go to an INDY shop that has experienced mechs and a good dyno. I am sure they would work with the PC! Or just look on here for the thread to do the cams yourself then take it somewhere to get tuned! But you HAVE to get a tune for that thing to run right with a cam install... Every bike is different. My opinion!
  • Why would you get cams installed at the dealer??? Bike Warranty
  • Or just look on here for the thread to do the cams yourself: It's like changing my oil. I can do it. I just don't want to.
  • But you HAVE to get a tune for that thing to run right with a cam install: I just need the map to get the bike running. Then I'll take it to a tuner.
Old Jul 9, 2012 | 12:57 PM
MOSTWANTED's Avatar
MOSTWANTED
Have you contacted dyno jet directly? Maybe they can steer you in the right direction. They have a list of facilities in your area that support their products.
Old Jul 9, 2012 | 07:55 PM
jeff.georgalas's Avatar
jeff.georgalas
I think you're "over worried" about warranty. Even with the dealer installing your cams, I believe that all SE stuff is "for off-road and racing use only", meaning that it's a non-warrantied item. Your individual dealer may honor some sort of in-house warranty, but I don't believe the moco will. And if they'd harrass you over the warranty, they'd also harrass you about using a PC vs. a SEPST.
Old Jul 9, 2012 | 08:27 PM
Hrlyrider's Avatar
Hrlyrider
just get a close map and you can add auto tune to the pcv, this is what I did and my bike is running better every time I take it out.
Old Jul 9, 2012 | 09:42 PM
vickers1's Avatar
vickers1
Did you change cams?
Old Jul 21, 2012 | 01:40 PM
Scared's Avatar
Scared
Any updates? I'd like to see what your bike did on the dyno after the cams...
tigger01291958
Oct 30, 2015 04:01 PM
harleyglen
Oct 21, 2014 12:47 PM
supra0001
Apr 16, 2013 05:39 PM
10350
Sep 28, 2011 05:25 PM
cactusred
Sep 28, 2009 08:17 AM
