se racing tuner or power commander???
Old Jul 9, 2012 | 07:41 PM
jgwoz's Avatar
jgwoz
Default se racing tuner or power commander???
I have a 06 ultra classic with a big bore 95" with hq 34 gear dr cams high flow oil pump se clutch upgrade tru duals vh headers and rhine hart 3-1.2 slip ons. My indy was mentioning that I might want to swap from the se racing tuner to a power commander that way I am not having to run to a dyno man or the stealer ship every time i make a change. He says I would have to have the se tuner wiped clean by the dealer and start new. Any opinions would be appreciated thanks
Old Jul 9, 2012 | 07:53 PM
1sweetglide08's Avatar
1sweetglide08
I would also look at the TTS Mastertune. You can then tune it yourself.
Old Jul 9, 2012 | 07:58 PM
XARAN's Avatar
XARAN
If you already have the SERT I'd stay with it. I'd rather have a flash tuner than a piggy back as long as you have someone that knows how to use it.
Even with the PC you need a Dyno to dial it on unless you plan on running a canned map and these are available for SERT.
I your going to change look at TTS or Power Vision you can self tune with these
Old Jul 9, 2012 | 08:00 PM
jeff.georgalas's Avatar
jeff.georgalas
Yup, either the TTS, of PC with an autotune feature, that way if/when you do future upgrades you won't have to pay for a dyno each time.
Old Jul 9, 2012 | 08:09 PM
Sath's Avatar
Sath
If it is running good I wouldnt change a thing. If you are planning future mods that would require a different tune I would probably stay with the SE tuner and do all the mods at once. Unless you can find a map for your build most likely you will have to dyno tune anyways. For best results always dyno tune.
Personally I chose to go with the Power Vision for the reason your indy stated but there were two other reasons. The first is I didnt have a tuning device to begin with and second the Power Vision is like the SE tuner, meaning it does not have to plug in and stay with your bike. It is one less electrical component along with electrical connections that may fail. Not to mention most HD dealerships will not work on a bike with a PC when trouble shooting electrical and tuning issues.
Jmo
Sath
Old Jul 9, 2012 | 08:44 PM
Flhrhog's Avatar
Flhrhog
I went with the power commander from fuel moto and am very happy.
SpiderPig
Feb 8, 2016 03:29 PM
pswomack
Jan 11, 2012 08:02 PM
theshotman
Mar 4, 2011 08:50 PM
Bad Disposition
Oct 23, 2009 11:55 AM
Cabo
May 16, 2007 06:05 PM
