Just loosen the factory trim ring via the small screw on the bottom.......Get your new trim ring on (make sure it goes around the lip of the factory ring) and slip a phillips screw driver in through the gap and tighten up your factory trim ring......Then tighten up the new trim ring.
I had the regular frenched visor on the headlight to hide the light after changing to a Phase 7 LED, then I changed all my lamps to the visor type. Didn't have a gap on either.
