If I had paid attention to what the grease marks meant I would have caught it sooner instead of it looking like this. You can see there are no ball bearings left in the upper cup. I could hear a scraping sound but couldn't figure it out until it was too late, I had stock pipes I'm sure I wouldn't have heard it with louder pipes. I don't remember if I felt anything prior to what was almost total failure.
This was at about 11k miles
That's how mine looked at 17000 miles, was making a chirping sound and then felt it in the bars. Was on a road trip out of state in Tenn.
Still have the orginal bearings (front and rear on My 08 UC) 46K, 3rd set of tires. Knock on wood! Update: 50K, still no Problems!, But will be checking the bearings.
I went in for a front tire yesterday at 36K and both sides of the front wheel bearings were shot. Hate to say this but is seems pretty premature since my last two bikes were will over 100K and never had front wheel bearings replaced. If you have the wheel off, take a rag and stick your fingers into the inner sleeve (where the axle goes through) and twist the bearing back and forth, should make no noise, my sounded like some one using a file on an iron plate.
I'd agree that it's probably the tire you're feeling. Although bearing failures have occurred as evidenced here and in other threads, at your mileage it's not rally all that common. I think you'd also hear/feel it going straight, not only in turns, even though it may be more pronounced in a turn.
You could simply lift the wheel and rotate it to check the bearing. It should feel smooth and no noise. If you remove the wheel it's really easy to check... The bearing should feel somewhat tight and perfectly smooth when you rotate it.
