Securing Saddlebags
Old Jul 22, 2012 | 09:19 AM
pinecroft's Avatar
pinecroft
Default Securing Saddlebags
For those of you that are using a j-nut and bolt or even the Brukus hardware to secure your saddlebags --- are you also using loctite on the bolts??? paul
Old Jul 22, 2012 | 10:14 AM
The Q's Avatar
The Q
I have the Burkus system on my Street Glide and fender / J nuts on my wife's Softail Deluxe bragger and have never had any problem with them coming loose. And I have never used loctite on either one. Honestly never even given loctite any thought.
Old Jul 22, 2012 | 10:22 AM
7Sixpack7's Avatar
7Sixpack7
Nope.. Do have a lock washer though..
Old Jul 22, 2012 | 10:39 AM
HarleyGyrene's Avatar
HarleyGyrene
Yep. Brukus and NOTHING goes on my bike without a little dab of LocTite. Just a habit and my .02
Old Jul 22, 2012 | 10:43 AM
bburn's Avatar
bburn
Nope, no loctite. I take my bags off to clean and work on the bike fairly oftem so I wouldn't want them loctited. Never found them to be loosened up any at all.
Old Jul 22, 2012 | 10:46 AM
Hammerhead Pat's Avatar
Hammerhead Pat
No loctite, just use the lock nuts with the nylon in them.
Old Jul 22, 2012 | 10:57 AM
stro1965's Avatar
stro1965
No loctite and have never found them loose.
Old Jul 22, 2012 | 11:31 AM
WICK's Avatar
WICK
Nylon lock washer with a split cotter pin just in case
Old Jul 22, 2012 | 11:34 AM
pinecroft's Avatar
pinecroft
Thanx for all the replies! I did have one of the bolts vibrate right out of the j-nut on the left saddlebag (which does vibrate more). Perhaps I didnt tighten if enough?? I appreciate all the suggestions. paul
Old Jul 22, 2012 | 11:42 AM
ocezam's Avatar
ocezam
Ditto. Loctite is a Harley builder's best friend
As long as you use blue locktite, there won't be any problem getting them off. I do it all the time.
Why would one bag vibrate more than the other? Are the brackets that the J- Nuts or Speed Nuts attached to loose?
