Rider backrest
Old Jul 23, 2012 | 12:43 PM
Harleybike's Avatar
Harleybike
Default Rider backrest
I have a 2010 EG Classic, FLHTC, looking at rider back rest and adjustable mount. Is there a reason (I know the bike is wider and taller than pre 09) that I cannot use a kit from a pre 09? Seems I read somewhere that there is an inexpensive part to allow pre 09 to fit 09+? Is that accurate or no? Do I have to stick with the 09+ kit/part#? Thanks.
Old Jul 23, 2012 | 01:32 PM
Twillis's Avatar
Twillis
Somebody on here made a little front mount that they modified a piece that they bought from home depot or lowe's. Might take a little searching, but it's in one of these threads.
Old Jul 23, 2012 | 01:55 PM
Harleybike's Avatar
Harleybike
Ok thanks. I did a search before I started this but I will look some more.
Old Jul 23, 2012 | 07:37 PM
Mike_M's Avatar
Mike_M
Looks like the only difference may be the holes in the bracket that holds the adjustment lever--if so, then I probably have a pre-2009 on my 2011.
I picked up an adjustable backrest used, only issue with it was that the holes in the bracket for the adjustment lever didn't line up with the holes in the frame. I marked where a hole should be on the bracket, drilled and then tapped the hole in the bracket, then put the screw through the frame and into the bracket--didn't need the little clip nut, and holds it pretty good (hasn't budged in over 10k miles).
Old Jul 23, 2012 | 08:41 PM
Harleybike's Avatar
Harleybike
Hmmmm, so the actual mounting bracket for the seat fit fine? I have talked with 2 dealers who said pre 09 won't work on 09+....Of course they want to sell us new but I dunno....diff part numbers for sure.
ACLazer
Touring Parts
Oct 9, 2012 05:07 AM
Akitakoi
Mar 18, 2009 01:38 PM
Badfinger
Dec 28, 2008 07:53 PM
crp5
Dec 7, 2008 08:11 AM
ranman469
Nov 24, 2008 10:18 PM
