I am wondering if any of you have this issue, I have a 2012 RK, I recently added astag one air kit new Vance and Hines big shot pipes and a Screaming Eagle super tuner.
My bike runs great but it seems that every time I let off the throttle I get some popping, nothing big or loud but it seems that it does it every time no matter how fast I'm going.
I had the deale rdo the tuning because I found out after I bought the tuner, you don't get the disc or cables needed to do it yourself, not that I could have. Anyway is this a normal deal with these types of pipes or can I get it tuned in a little more where I don't get as much popping?
Also check your exhaust for leaks as this will cause the popping on decel.
cheers
+1 .. even a slight leak will cause this .. Spent a bundle getting tuned to perfection and all it was a slight leak at the muffler clamp .. If no leaks, a slight crackle at Decel may be no problem ..
I belive that it is mostly popping at RPM changes, the wather has been pretty steady here for the last month or so. Sothern Indiana, mostly low to mid 90's
