Throttle cable
Old Jul 29, 2012 | 09:37 AM
fwb35's Avatar
fwb35
Default Throttle cable
Yesterday as I was adding new trinkets to my 99 EG Standard I noticed as I was changing the switches my rear throttle cable is fraying. Is this a easy job or should I let my wrench do it? I am experienced at working on race cars but this is my first touring HD and have limited experience working on them, I did successfully change out my switches from black to chrome lol
Thanks
Old Jul 29, 2012 | 09:49 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Hardest part of the job would be to remove the front fairing.
Old Jul 29, 2012 | 09:53 AM
TUCCI's Avatar
TUCCI
If you've got that kind of experience this will be right up your alley and it will only ensure its done right. The more you know about the intricacies of your bike the better off you will be in the long run.
Old Jul 29, 2012 | 10:04 AM
fwb35's Avatar
fwb35
So the front faring has to be removed?
Old Jul 29, 2012 | 10:07 AM
V-Twins & Bowties
Yes. Also the tank. Then you can access the cable for removal and install. Just be sure upon reassembly that you do not pinch or bind the cables.
Old Jul 29, 2012 | 10:12 AM
Notgrownup's Avatar
Notgrownup
You may be able to do it w/o removing the tank...we changed one on my one of our riders on the side of the road...Didn't have to take the tank off , the fairing was a aftermarket one so maybe a bit different.
Fairing is the easy part...Everybody that has a bike with a fairing should at least know how to remover it....Basic stuff...
Old Jul 29, 2012 | 10:19 AM
V-Twins & Bowties
I should have stated the fairing was the time consuming part.
Old Jul 29, 2012 | 10:20 AM
fwb35's Avatar
fwb35
I just found and read the instructions on throttle replacement for my bike, 99 EG Standard, it does not say anything about having to take the faring off or the tank. Could mine be different since most of you guys have newer bikes?
Old Jul 29, 2012 | 10:29 AM
V-Twins & Bowties
I suppose you can try and fish the cable through but alot easier with the fairing off.
Old Jul 29, 2012 | 10:38 AM
TWIN CAM 96's Avatar
TWIN CAM 96
You only need to pull the front half and the headlight pretty easy to do.
