Throttle cable
Old Jul 29, 2012 | 11:16 AM
Notgrownup's Avatar
Notgrownup
Originally Posted by fwb35
I just found and read the instructions on throttle replacement for my bike, 99 EG Standard, it does not say anything about having to take the faring off or the tank. Could mine be different since most of you guys have newer bikes?
Yes... I would try without removing it... Hell i can take my fairing off my bike in about 2-3 minutes at the most. 7 screws...
Old Jul 29, 2012 | 12:46 PM
chateau's Avatar
chateau
Mines an 04 classic , and yes the front fairing is a breeze to remove.I take the headlight out first , nice time to do some deep cleaning. I made me some small spacer blocks to jack up the tank after all the proper mounting bolts were removed , and was able to gain enough access to remove and replace the cable. Spacer blocks were just made from some 3/4 wood stock. Good luck , you can do it. Make sure you use the new ferrel that comes with the cable . Don't drop it , they have a way of dissappearing.
Old Jul 29, 2012 | 01:05 PM
fwb35's Avatar
fwb35
ok, thanks guys, will give it a shot, just never tried pulling the faring, is my first faring bike so im trying to learn, Thanks
Old Jul 29, 2012 | 03:44 PM
Bill03E's Avatar
Bill03E
Get the new cable, take the old cable loose from the throttle body, tape the new cable inline with the old one, pull the old cable out up to the bars, your new cable will be laced in exactly the same way as the old one, then you just have to hook up the ends.
Old Jul 29, 2012 | 08:39 PM
fwb35's Avatar
fwb35
How can I do that with the metal ball on the end? Do you mean the whole cable, not just the inside cable?
Old Jul 29, 2012 | 08:58 PM
Bill03E's Avatar
Bill03E
yes I mean the entire cable, I do this but pull the outer faring, so I can help it make the turns in the faring, it is just easier to route.
Old Jul 30, 2012 | 07:37 AM
fwb35's Avatar
fwb35
It is the idle cable, rear one on the grip, the throttle cable looks fine, should I replace both while in there?
Old Jul 30, 2012 | 08:57 AM
1flhtk4me's Avatar
1flhtk4me
As long as the cable is not frayed or kinked,it should be good.Be sure to lube both of them.
Old Jul 30, 2012 | 09:25 AM
fwb35's Avatar
fwb35
Very good, thanks guys!!
Northbound Southerner
Aug 28, 2013 09:21 AM
bigdano
Sep 2, 2011 09:35 AM
Bruce in Montana
EVO
Jun 10, 2010 06:42 PM
GONZEE
Feb 1, 2009 08:52 AM
wlbowers
Mar 10, 2007 09:08 PM
