Resetting a Throttle Sensor
Old Jul 30, 2012 | 05:15 PM
zbuxton's Avatar
zbuxton
Default Resetting a Throttle Sensor
Does anyone know if there is a con to resetting a Throttle sensor. I read on here to do it you turn the ignition off and swith the kill switch on. Turn the ignition on and off 3 times then on the 4th let it run for 5 minutes? Anyone have an opionion on this being good or bad?
Old Jul 30, 2012 | 05:18 PM
Delta's Avatar
Delta
Had to do this twice on my 08 Ultra. It works, nothing wrong with it. I think that you have to wait 10 seconds between each movement of the ignition switch. Not sure of this though. It's been a while.
Old Jul 30, 2012 | 05:24 PM
zbuxton's Avatar
zbuxton
awesome thanks! It doesn't hurt anything with the race tuner or any other settings?
Old Jul 30, 2012 | 09:10 PM
ftzoid's Avatar
ftzoid
You don't have to let it run for 5 minutes after the reset either.
Old Jul 31, 2012 | 12:35 AM
zbuxton's Avatar
zbuxton
great! thanks for all the help.
Old Jul 31, 2012 | 12:43 PM
57red's Avatar
57red
i need the procedure too, have the power vision it keeps saying successful when i clear the codes but they pop right back up. and now my cruise won't work.
Old Jul 31, 2012 | 01:40 PM
skratch's Avatar
skratch
if you are successful in clearing the codes, but they keep popping back up, then you have a continuing problem that needs to be addressed.
Old Jul 31, 2012 | 03:06 PM
zbuxton's Avatar
zbuxton
I know this isn't really the thread for it but...Does anyone know what would cause a p1510 error and also the throttle sensor error when I turn my bars all the way to the left (stand side). The bike has no symptoms however gives the check engine light when this happens and those codes?
Old Jul 31, 2012 | 03:19 PM
Bo Joe's Avatar
Bo Joe
Just had to do the reset. No issues with it.
You turn the ignition on, wait 10 seconds. Then turn the ignition off, wait 10 seconds. Do this 4 times and you're done.
Works like a charm.
Old Jul 7, 2020 | 06:23 AM
b_electric's Avatar
b_electric
5th Gear
Works like a charm.
i think the significance is the fuel pump? I've never had any issues at all once I started waiting for it to finish initiating after flipping run switch. You can hear it and there's an icon that lights up. When the sound is stops and that icon is no longer lit, thenI hit the start button. Never before or during that sequence.
