Floor jack?
Old Jul 30, 2012 | 11:14 PM
Groucho1's Avatar
Groucho1
Default Floor jack?
I have a floor jack...one of those that you get at Sam's or Searswith a foot paddle you raise it with.... I have used it for my lowrider,my Corvette and now I'm wondering if there is an issue where the frame meets the flat part of the jack on the road king.
Has anyone had any problems with these types of jacks?
Old Jul 30, 2012 | 11:33 PM
Big E1's Avatar
Big E1
Have the yellow jack from sears works great on my road king.
Old Jul 31, 2012 | 12:01 AM
Irish Joe's Avatar
Irish Joe
I've got the yellow sears one, also. I agree, works great on my Street Glide.
Old Jul 31, 2012 | 12:06 AM
baust55's Avatar
baust55
I have the Harbor Freight Yellow lift . it was $59 plus tax with coupon .
I also have Black Widow Sissor jack i bought on Amazon for $69
I use them both on my 200g FLHRC and my GFs FXR3
Groucho1's Avatar
Groucho1
Mine came with 4 rubber mounts that I used on my Wide Glide. They attach to the frame of the bike. I think they were just because the frame was uneven on the FX frames. It looks like the Road King frame is flat all the way on the 4 points of contact with the jack.
Any special way you get it to sit level while your putting the jack up ? The WG was alot lighter and I just left it on the stand and raised it up slow.
Old Jul 31, 2012 | 06:59 AM
2ropes's Avatar
2ropes
I have one of those Sear floor jacks I use on my ATV's but never thought of using it on the bike. Unfortunately my jack and ATV's are 200 miles away from where I keep the RK but I could bring it here to use. When you use a jack like this do you strap the bike to the jack?
I have been looking at the PitBull jack or J&S but if the Sears works ok I'll just transport it here and put the money in handlebars!
Old Jul 31, 2012 | 08:06 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I also have the HF yellow jack, it has rubber strips that contact the frame so there is no slide. With practice you will find the sweet spot to place the jack where the weight is about equal fore and aft and the bike will be very stable. I do not tie mine down, but I do set the lift locks when it is raised. Just always be sure you have the jack far enough under it where the opposite side gets a good bite, an inch or so is good.
Oh, and from time to time I lay my jack on its side and lube the wheels with a little oil to make rolling the jack with the bike on it around a little easier...
Old Jul 31, 2012 | 09:06 AM
Leftcoaster's Avatar
Leftcoaster
Having trouble understanding exactly what kind of jack you have. I certainly wouldn't try to raise a car with either of my bike jacks but maybe yours is strong enough to do that.
Anyways, I usually put the rear lift platform underneath the frame cross-member which is just behind the oil pan underneath the bike. That usually centers the bike enough that it's pretty well balanced on the jack. I always check for balance before I raise the bike fully.
Old Jul 31, 2012 | 09:20 AM
mikelikesbikes's Avatar
mikelikesbikes
Ditto and once jack starts to raise the bike I inspect both sides to make sure all 4 contact points are good. If so I lift the bike. If not I lower and adjust.
Old Jul 31, 2012 | 10:15 AM
Terrabella's Avatar
Terrabella
Sure doesn't look stable to me. Caption should be: Wild man raises Harley on Sears yellow jack. Get back boys, give him plenty of room!
