S/E air cleaner. With the new backing plate, you can retain the stock cover. I think there're more alternatives out there, but I can't recall at the moment.
One thing you can do is get the cheapest SE AC (the cast grey one), get some Hi Temp flat black spray paint and paint it before you install it. I did this 2 years ago and it still looks like the day I did it. It blends into the motor very well.
I believe the Fuel Moto stage I kit will work with the stock AC as well....I went with the SE AC, but if I had to do over, I would get the Fuel Moto
I am just the opposite. I started with the FM back plate, but took it off and went with the SE. I prefer the the crankcase vent through the casting on the SE instead of retaining the short rubber hoses.
If you use the hd SE backplate remember to save and not throw out the bracket that presently is used on the stock backplate. You won't need it with the SE system but you will need it if you ever decide to go S&S. Ask me how I know. Just save it.
