Compression Release Stuck
Old Aug 6, 2012 | 04:47 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
Default Compression Release Stuck
The compression release on my rear cylinder is stuck in the down position. Any ideas what to do? Is there a way to free it, or do I need to replace it?
Old Aug 6, 2012 | 05:46 PM
MareRider's Avatar
MareRider
Manual or electric? Buddy has the manual style. When one starts acting up he'll take it out and clean it using brake clean.
This will get him by for a while, but he'll end up buying amother one.
Old Aug 6, 2012 | 05:50 PM
dbell66253's Avatar
dbell66253
MareRider asked the same question I was going to ask, manual ones can be cleaned, if it's electric, replace it.
Old Aug 6, 2012 | 06:55 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
It's manual. I'll pull it and see what's what.
Old Aug 6, 2012 | 08:05 PM
bagman1's Avatar
bagman1
Spray penetrating oil on it should do the trick without pulling it out.
Old Aug 7, 2012 | 08:03 PM
2009blackpearle's Avatar
2009blackpearle
Default oiled mine
i had manual ones on mine and they both stuck quite often, i pulled it out and spayed oil in tappered valve on end while open and small vent on side worked up and down put back on bike usually ok for about 2 months.
Old Aug 7, 2012 | 08:24 PM
EasternSP's Avatar
EasternSP
WD40 works. On the other hand, the S&S EZ start cam doesn't need CRs.
Old Aug 7, 2012 | 08:34 PM
soft 02's Avatar
soft 02
Soak it in a spray paint can lid that has a good penetrating oil in it like PB Blaster or Kroil. Use an ld tooth brush to remove built up carbon. The other one is prolly next.
Old Aug 7, 2012 | 08:51 PM
1HD2NV's Avatar
1HD2NV
Had SE MCR's for 1st 30,000 miles. Never cleaned them until I started having issues and by then if was a short term solution. Bought a set of Wood's which I like much better and am doing a PM cleaning at every service (5K) and hope this makes a difference. Spray them down with carb cleaner, then soak in same for about an hour.
amkaos
Oct 5, 2014 08:39 PM
windycity
18
Feb 23, 2013 08:25 AM
cptdenny
Aug 30, 2010 11:21 PM
deadduck357
Apr 21, 2010 03:57 PM
jackinthebox
Exhaust System Topics
15
Jun 9, 2009 08:35 PM
