Ultracool question
Old Aug 6, 2012 | 11:35 PM
Born2cure's Avatar
Born2cure
Default Ultracool question
I went with the Ultracool oil cooler after much research on the forum. Thanks everybody for the help. I'm down to placing the LED for the fan. Where did you who have place it, any placing and not drilling into fairing. and picture would be great. thanks
Old Aug 7, 2012 | 12:13 AM
senna's Avatar
senna
Do you have any empty switch holes on either side of the ing switch?
If so, I would consider placing it in one of those.
Old Aug 7, 2012 | 06:02 AM
Born2cure's Avatar
Born2cure
All go them used head lamps, cruise, speakers, aux. maybe I can run up in that area. Will look. Thanks senna
Old Aug 7, 2012 | 08:44 AM
captainjack's Avatar
captainjack
put mine through the clutch cable hole
Old Aug 7, 2012 | 09:13 AM
sfckelley's Avatar
sfckelley
Put mine next to the cigarette lighter. It's a little hard to see, but I didn't want to mess around up by the gauges. I really considered not putting it on at all.
Old Aug 7, 2012 | 09:57 AM
aviscomi's Avatar
aviscomi
+1 I also put mine through the clutch cable grommet.
Old Aug 7, 2012 | 10:31 AM
White Ice's Avatar
White Ice
Does the fan require an LED? If it's just there to indicate that the fan is running I would leave it in the box.
Old Aug 7, 2012 | 11:30 AM
aviscomi's Avatar
aviscomi
No its just an indicator
Old Aug 7, 2012 | 11:45 AM
drukanfu's Avatar
drukanfu
You want to put it where it's shaded so you can see it in bright sunlight. I ut it just under the winshield bags. Needed to drill a 5/16" hole, you can always plug it.
Old Aug 7, 2012 | 12:09 PM
Esuomm1's Avatar
Esuomm1
Drill it in, it will look cool.
