Ultracool question
Old Aug 7, 2012 | 05:52 PM
Born2cure's Avatar
Born2cure
Thanks guys I put it the clutch cable hole till I grow a set to drill.
Old Aug 7, 2012 | 05:56 PM
Born2cure's Avatar
Born2cure
One more question. I was riding about 30 min to check it out. Pulled in for gas noticed the light was on. I must be hot enough to turnfan obeven I motion. Granted it is 90+ in Chicago area. Was just wondering if I'm running hot. Guess next investment oil temp guage.
Old Aug 7, 2012 | 06:59 PM
drukanfu's Avatar
drukanfu
Fan comes on at 230 deg. Off at 190 deg. You'll go into limp mode after that.....and so what ! Thats what it's there for, besides your synthetic oil is good for 400 + degrees. And your motor can go hotter than that ! Hell, I cook pizza at 450 deg. and it doesn't melt my cheap pizza pan !
Old Aug 7, 2012 | 07:51 PM
dbell66253's Avatar
dbell66253
If you rode in 90 degree weather for 30 minutes before it came on, your ok. An oil temp guage is good, lets you see where the fan is coming on, and is a good reference point, if you do get one, check the accuracy if it to determine the real temp you are reading.
Old Aug 7, 2012 | 08:24 PM
Born2cure's Avatar
Born2cure
Good point about the pizza oven. How would you check the Accuracy of the guage.
htoler
Oil Archive (no new posts)
13
Mar 12, 2019 02:24 AM
huntersot
Audio Systems
Mar 30, 2016 06:34 PM
shortleg
Apr 7, 2014 11:26 AM
A Whole lotta Rosey
Apr 8, 2013 01:42 PM
voodoodrug
Dec 16, 2006 07:13 PM
