gps and speedo comparison
Old Aug 9, 2012 | 05:20 PM
07FLHT's Avatar
07FLHT
Here in So Cal we have a lot of radars in school zones that post your speed your traveling. My 07's speedo always showed faster than those and my GPS by 5+ mph! When on a road trip with a buddy last spring (riding side by side, him on a 06 SG) I got way better gas milage than he did cause I'd always ridden a several more miles between gas stops! LOL! All was good once I changed to 18" wheels (from stock 16'"s) front & rear.
Old Aug 9, 2012 | 05:30 PM
Hard Ride's Avatar
Hard Ride
My 06 Ultra and the GPS is spot on...
Old Aug 9, 2012 | 05:34 PM
pgpn's Avatar
pgpn
Thanks for the info. It is a 255w to be exact.
Old Aug 9, 2012 | 05:38 PM
Hrlyrider's Avatar
Hrlyrider
according to my GPS my top speed was 102 and yet my speedometer said 118
Old Aug 9, 2012 | 05:49 PM
J.L.'s Avatar
J.L.
Some GPS will give you speed over the ground, which is not the same as a road that is not perfectly straight. In other words the gps may read your route from point to point which are spaced out and are not the same as your bike following the curves in the road. The GPS will not match the speedo at all times because of this.
Old Aug 9, 2012 | 06:12 PM
JB's Avatar
JB
Ive checked 3 different GPS's and all readings were identical at speed. One was a Tom Tom 1XL one was a Garmin 1490 and the third was a hand held unit of my boss's. The speedo's on both my 87 and 2011 ultra read 3-4 mph faster then then the GPS's
Old Aug 9, 2012 | 07:10 PM
Z2871RSBB396's Avatar
Z2871RSBB396
the faster I go over 60 seems to make it worse, 45 and below it is on. ODD? I think so. It is off 3 mph @60, at least it errors on slower speed than actual
Kirt
Old Aug 9, 2012 | 07:15 PM
wlibert's Avatar
wlibert
Mine is 3 to 5 mph over depending on the speed. Just think how many miles are on your ODO that you really didn't ride!
I have a PowerVision tuner but I can never seem to find the time to correct the issue.
Old Aug 9, 2012 | 08:16 PM
K Melancon's Avatar
K Melancon
Your GPS should be accurate. All vehicle manufactures set the speedometer 2 miles faster than true speed to give a safety margin. Then as your tires wear it will change slightly more. Next time you go to change out set of tires see how much its off. When you put the new tires it should be back to 2 mph off. This is with the OEM sized tires.
Old Aug 9, 2012 | 09:35 PM
duanew18's Avatar
duanew18
The bike's spedo will always display 3-5 mph faster than you are really going. I always use my Garmin 3490LMT for my speedo.
